5E3 Amp Build
  • hotpickupshotpickups Frets: 1822
    RiftAmps said:
    Barnezy said:
     No, definitely not normal, and the lamp is lit up too?
    Is that a 100w filament lamp you are using?
    Also it does not look like you have the PT bolted down properly?
    60w bulb. The dim bulb tester, isn't lit up anymore than if I plugged another device in. It's not lighting up as if there is a short.
    One nut is missing as I moved the earth across one. All others are tight. Put the last one back now.
    As mentioned, when I placed a box under it and leveled it the noise stopped. Voltages are being delivered as they should be.
    A 100w bulb is better in this application. It'll allow up to 416mA of current (see Ohms law) at 240v which still is lower than the consumption of nearly every guitar amp >5w but crucially, it won't glow in a non-fault condition such as powering up with no valves installed. A 60w bulb will emit a slight glow, which may confuse the user into thinking there is a fault when there's not.
    Nice build BTW!
    And this is exactly why I wanted to do one of @RiftAmps amp build courses :) Chris knows his stuff and I’ll be in safe hands
  • BarnezyBarnezy Frets: 2200
    Thanks guys.
    I did try to find a 100w bulb in the shop, but good luck. I had a 60w in the house, so went with that. The bulb is very dim, in the video it looks brighter than it is.
    Thanks @RiftAmps , I appreciate the compliment, praise indeed coming from you.
    Thanks @Modulus_Amps for responding so quickly. Lesson learned, always tighten all bolts on the PT. :)
    @hotpickups if you're not comfortable dealing with electricity, then doing a course might be best. You just really need to take care and follow the rules you've learnt your entire life. You wouldn't stick your fingers in a toaster, so don't do it in a live/charged amp. I believe there is a lot of fear about amps, due to the charge held in a filter cap, but if you treat the amp the same as if it is plugged in, until you've discharged the caps, then you're good. Discarging the caps isn't hard or scary. Here's my home made device a 5W 2k resistor, a pice of wire, two lolly sticks and some insulation tape.
    Hopefully I'll have a video to post of it up and running by the end of today!
    DONE.
    All finished. Final testing and in to the cab.
    I've had about 20 minutes on it so far and really like it! The speaker is brand new so looking forward to that breaking in.
    I've really enjoyed this build and have learnt alot along the way about how an amp actually works. I would highly recomend it to anyone considering doing this!
    I'll get a vid up in the next few days.
    0reaction image LOL 12reaction image Wow! 0reaction image Wisdom
  • KeefyKeefy Frets: 2288
    Well done! Building your own amp is very satisfying, now enjoy it :)
  • RaymondLinRaymondLin Frets: 11879
    Have a wow, but the speaker at 90degrees is bugging me.
    Haha thought it would be better for access to the terminals. I noticed alot of amps come like this. Not good for OCD I realise.
  • Modulus_AmpsModulus_Amps Frets: 2583
    Nice and well done, for a first build you have done a great job! better than some boutique amps I have seen anyway.
    Never heard one with that speaker actually, really need to get one myself, last time I looked them up they said they took a while to break in, but once they had, they sounded really good
  • TTonyTTony Frets: 27628
    Nice work - that looks really neat and tidy.  Encouraging to read that it *can* be done too ...
    I was actually booked to do Chris' course in March.  As it happens, he had to cancel the day (due to non-Covid illness) and we thought no-biggie, do it the following month.  Little did we know ...
    Barnezy said:
    DONE.
    What model Jensen is that?
  • springheadspringhead Frets: 1597
    Well done!  Very satisfying.
    Keefy said:
    Barnezy said:
    DONE.
    It's a P12Q. I read a lot of 5e3 forums and many said the was the best bar a Webber, which seem to cost a fortune to ship over here. It's pretty cheap, £95, so thought it was worth a punt. It's 40w so should avoid too much speaker breakup, which I can't sat I'm that keen on.
    Its sounds very stiff at the moment, but I'll play some heavy music through it for a couple of hours a day and see where we get to in a few weeks.
    Thanks Michael. Deffinately enjoyable. I'll be doing a Priceton next :) I'll be in contact soon.
  • Chris.BChris.B Frets: 288
    Well done, that is a great looking and very neat build, something to be proud of.  Looking forward to seeing and hearing it in a demonstration video.
  • mattacjonesmattacjones Frets: 506
    I am hugely impressed!
  • mattdavismattdavis Frets: 841
    That is amazing. Really well done!
  • JonathangusJonathangus Frets: 4546
    Tidy!
    We'll neead to hear clips, though.
    Trading feedback | How to embed images using Imgur
    As for "when am I ready?"  You'll never be ready.  It works in reverse, you become ready by doing it.  - pmbomb
  • RockerRocker Frets: 4986
    Very impressive work, well done.
    Nil Satis Nisi Optimum
    So the finishing touches are now done.
    Shellac'd the tweed and put the faceplate on. Speaker is starting to break in, so will post a vid soon. Loving the simplicity of the amp. Using it with a Nightlight Jr attenuator so able to cranck in to overdive. So much better than any pedal.
    Before
    Durring
    Finished
    Happy ending!
    Lazy J are getting nervous ;)
    I’m getting seriously tempted to just get a kit and crack on.
    I was going to do Chris’ course to *learn* the basics first, but maybe I’ll have to get a kit first, and do the course second.  That way, I guess I might have more experienced questions to work through on the course.
    Tempting, tempting, tempting.
