1) Analog Dry Through going to 0. It's easy to workaround, and just have to set back and save, then it persists. But it's a clear bug that should be addressed (this one is not a dealbreaker for me)
2) Adding a delay to either the Room or E-Dome reverb engines, adds some volume and an unpleasant tone - forcing me to use the parallel mode. It doesn't happen with other combinations, but it is very noticeable and makes them unusable in combination with cascade mode. I tested with a long delay, kicking it in and out - really not nice.
If the 2nd one is addressed, I'll keep it. I agree with you, it sounds really amazing and natural. My preference is to hold it, but have a week left to decide if it's going back!
Perhaps yours has the same behaviour? If you have a spare minute, would you mind testing it?! Room with a digital delay for example, but a long tail. Just hit a chord and kick the delay in and out, see if the tone/volume changes.
Interesting to hear about the Immerse, sounds like I need to wait a couple of days and see if it is addressed. I love the plate and spring on the Collider, and probably use those the most (and they are not affected with the above issue!).
The S.A support is generally great off the forum, so fingers crossed! I'll post here once I know more!
For those concerned about the pedal - there clearly are a few bugs that need to be addressed. The quality of the effects are really excellent however, so I'm really hoping the issues are resolved. Normally I would have returned it within a couple of days, but it is so good I have persisted with the support team!
I'll post an update here either way!
Been uploading old tracks I recorded ages ago and hopefully some new noodles here.
The Immerse sounds somewhat samey across a few of the options to me, going purely by demos admittedly, and not as capable as the Merc 7, so that's where I'm headed I guess.
As the new price has dropped to £289 in a couple or three places which helps tempt the trigger finger.
I'm still tempted despite the issues...
But the sounds are great!! I don't regret buying it.
