TC this time, at least 25% off. All the head stocks are drill for Kluson tuners (8.8mm front 6.3mm back). They all take standard off the shelf fittings unless otherwise stated. All the bodies are two piece centre joint.
£12 P&P on all guitars UK ONLY.
Left hand TC. Swamp Ask body chambered, neck Maple with a Rosewood finger board, 22 frets .100” X .050”. Bone nut 43mm, neck thickness 1st fret 22.3mm 12th fret 24.5mm. weight neck and body 5lb.
£240
F hole TC. Swamp Ash body fully chambered, neck Roasted
Maple with Rosewood finger board, 21 frets .100” x .050”, Bone nut 43mm, neck
thickness 1st fret 22mm 12th fret 24mm, weight body and
neck 4lb 3oz.
£240 SOLD
2 x P90 TC . Swamp Ash body, Maple neck with Rosewood finger board, 22 frets .095” x .045”, bone nut 43mm, neck thickness 1st fret 22.5mm 12th fret 25mm, weight body and neck 5lb 10oz.
£240. SOLD Smugglers TC. Swamp Ash body, Maple neck with a
Rosewood finger board, 21 frets .100” x .050”, bone nut 43mm, thickness 1st
fret 23mm 12th fret 24mm, weight of body and neck 5lb 7oz.
£240 (may be SOLD)
Thin Line TC. Swamp Ash body, Maple neck with a Rosewood finger board, 21 frets .100” x .050”, bone nut 43.2mm, 1st fret 23mm 12th fret 25mm, weight of body and neck 4lb 7oz.
The pick guard for body will need a slight modification at the bottom horn, a very small amount will have to be removed. The details of this in my post https://www.thefretboard.co.uk/discussion/177593/covid-19-im-now-in-total-isolation-so-lots-of-building-to-do/p1
£200 SOLD
Your life will improve when you realise it’s better to be alone than chase people who do not really care about you. Saying YES to happiness means learning to say NO to things and people that stress you out.
Why?
All the above guitars were shown being built in my main post and it does say that everything I make is for sale, unless it's a commission build, which I will say so as it's being built.I'm only a message away from finding out if I have in stock what you want to build, or if I can make some think for you.
LPJ,s and a SP6
. Head stocks are drill for Kluson tuners (8.8mm front 6.3mm back). All neck are fitted with a 2 way rod.
LPJ Single cut.
Mahogany body with a quilted Maple cap, part chambered, weight of body and neck 4lb 12oz. Bone nut 43mm, thickness at 1st fret 22.8mm , 12th fret 24mm, fret .100”x .050”, Routed for one P90, a second pickup could be added as there are wire runs are under the cap. This is classed as a “B” grade as the Quilt cap as a few marks on it.
£300 + £12 P&P
LPJ DC.
Made from Mahogany with a Rosewood Fingerboard fitted with 22 6100 frets, bone nut 43mm. Thickness at 1st fret 23mm 12th fret 25mm, weight of body and neck 5lb 8oz. Supplied with black pick guard and back plate. This is classed as a “B” grade as it a little overweight, also the Mahogany not very pretty.
£300 + £12 P&P SOLD
LPJ DC.
Made from Mahogany with a Rosewood Fingerboard fitted with 22 6100 frets, bone nut 43mm. Thickness at 1st fret 23.2mm 12th fret 24.8mm, weight of body and neck 5lb 12oz. Supplied with black pick guard and back plate. This is classed as a “B” grade as it a overweight, also the Mahogany it's not very pretty.
£300 + £12 P&P
SP6.
Body is made from Swamp ash with the book matched swamp ash cap, the body is partly chambered. The neck is a bolt on laminated 3 piece Maple with a Rosewood fingerboard fitted with 22 frets .080” x .040”, bone nut 43mm, thickness at 1st fret 22.6mm 12th fret 24mm, weight with neck 5lb 5oz The body is routed to take a standard TC bridge and control plate, with a P90 in the neck position.
£300 + £12 P&P SOLD
When you're back in the workshop,let me know what you've got.
All the best
My Trading Feedback can be found here: https://www.thefretboard.co.uk/discussion/62765/bad-alice/p1
If you are looking for a LPJ DC with a slimmer neck than I normally make, let me know as I will be making a new batch in two to three weeks.
like this:
but with the better body shape like youve done?
could you "open book" the headstock too?
what would you say is the closest gibson neck profile to these?
Thanks
