Les Paul Pickguard.
13»
  • EmielEmiel Frets: 215
    edited October 2020
    On a side note, any tips where to get ‘50s style Les Paul Custom black plastic hardware (mounting rings, toggle switch plate, jackplate)?
  • RaymondLinRaymondLin Frets: 11916
    edited October 2020
    Reverb has some, you need to check Dimensions though, mine came from Crazyparts and it was off by a mm at the bottom even though I made sure I got the correct era (99-08 Customshop Historics), measured it.  I spent ages with a nail file manually take off a mm of plastic off the bottom notch!
  • Off on a flame top on on a gold top
  • Devil#20Devil#20 Frets: 1986
    It's a shame that Gibson didn't have a non-destructive way of putting the pickguard on that didn't require you to drill holes. I was pickguard off but I'm undecided again now. Looking @RaymondLin guitar I'm thinking it looks better with it on. If it was a plain guitar I'd say off. Poker chip should always be on.
    Ian
  • My opinion on this has changed recently, I was off for a while but prefer it on now, something about it looks a bit more finished to me with it on.. I also didn't like the holes that were left when it was off, I wouldn't drill holes tho if my les paul didn't come with a pickguard
    Blue tac will work until you put any pressure on it.
    edited October 2020
    ICBM said:
    Skipped said:
    You can mess with this, but it is just "wrong" to do so IMO.
    The amazing thing is that she actually looks good like that - and I'm not a fan of tattoos generally.
    She looks better without them though (at least IMO) and I guess that's the point.
    thats weird..
  • WezVWezV Frets: 16780
    They did magnetic ones not too long ago
  • FezFez Frets: 535
    Cream ones off cos they look tacky black ones on.
    Don't touch that dial.
  • MudcrutchMudcrutch Frets: 323
    If is a old guitar leave it on because the body finish underneath it will be marked where the bracket is fixed under it.
    If it’s new Personally I think they look better without.
