However, I currently own one and have owned and played many that are fine and without fault.
This would possibly be expected if they were a budget brand but they're not even a normal priced brand, they are a very expensive brand.
I have a Memphis VOS 335, the bone nut was so soft the string windings were leaving indentations in the grooves and binding. It crumbled when removed. Also came from the factory with a deep dink in the finish by one of the F holes
I had an R8 that needed a finish repair by the nut, it had been chipped off in the factory
All of these guitars have razor marks on the binding. All retailed for over 3 grand. It doesn't change the way they sound or play, but it is a bit insulting to the consumer
On a scale of 1 to Gibson I would put the Eastman flaw quite near the bottom
