So, just a thought, the Fender LVL5 has 5x500mA - so if these were connected together to give 2,500mA presumably it would still be the same 9v overall & in theory shouldn't that be able to power my Pod Go too? If so, how do you connect them together - a 5-prong daisy chain or something else?
https://truetone.com/1-spot/
You have all analogue pedals, so that may be quiet enough on its own.
Then, if necessary, add one or more of these...
https://www.joyoaudio.co.uk/joyo-zgp-guitar-effect-pedal-filter-isolated-output-power
Used to have the fuel tank junior which had a ropey two pin power input. Didn't have problems with it but it always seemed flimsy.
The other annoying thing about it is the difficulty in getting it to stay attached to the underside of the pedalboard.
Hmmm. Not clear if this isolates outputs
