1. Yes they are still going.
2. Made from the same material as helicopter blades
3. Some people really like them.
4. Some people really dislike them.
(some of these are the same people)
5. Everyone agrees they are rubbish if you like to sit down.
6. Ovation owners make rubbish husbands
7. Val Doonican was a very nice man.
8. Val Doonican was a very nice man and a chatterbox.
9. I’m not going to buy one.
Her 12 string here sounds like a bag of nails by itself but works well in the band mix and instantly evokes the 1970s...
Tangent: always thought it cool that the posh stuff was called 'Ovation' whereas the cheaper stuff was branded 'Applause'.
Sounded pretty good to me.
They are good a for loud stage full band type gigs and can sound ok for amplified stuff. The pickup sounds thin and needs a lot of eq. Playing sitting down is frustrating. I don't play mine at home.
I've used mine on and off and some applications are fine. However I've mainly played electric and this year I wanted to get more into acoustic and bought a Martin.
On a photography assignment visit to Martin in about 1973 I was told that Glen Campbell who was a prominent user of Ovations at the time, used his for the photographs and TV and concerts but Martins for recording.
Of course, they may have been biased but, certainly, at that time, Martin's boast was that anyone who played a Martin had paid for it.
I got my first two when I was about to embark on my first proper support tour ( a couple of Custom Balladeers, one sunburst, one natural ). The main act was using them as well ( along with just about everybody else ) which meant that the sound engineers were on my side from the first soundcheck. I later had a Custom Legend ( very blingy ) and another guitar player I often toured with had a Glen Campbell ( the first model with a shallow bowl ). This was all from around 1978 to 1984. After that I got an Adamas ( very expensive at the time ), but by then I had also acquired a couple of Takemines, which while being the new kid on the block were head and shoulders above the Ovations in terms of live sound due to the better electronics ( EQ etc, Ovations were pretty much tone and volume at that time ).
I still have a respect and fondness for Ovations as they were the simplest way to get the job done as well as being very playable in terms of set up /neck profile etc. It should be remembered that acoustics with low profile necks etc were a way off in the 70's.
- very beautiful to look at
- multiple sound holes, designed to avoid feedback (they didn’t work as intended).
- noticeably radiused finger board
- lovely neck, very nice to play
- plug-in and play on stage, and it sounded every bit as good as most other expensive electroacoustics with piezo pickups at the time (until the Fishman Aura came along I suppose)
- the convex back constantly fought with the convexity of my belly…
- the lower area of the bowl back where it rested on ones thigh was roughened to reduce the risk of slippage (that didn’t really work either)
Overall however it was a really good instrument. I swapped it for a Taylor T5 with it's own limitations (now that's gone too)
