Bizarre Fact of the Day
  • Rolf Harris touched up Vanessa.
  • jd0272jd0272 Frets: 3867
    underdog said:
    The world's largest tyre manufacturer is Lego.
    NO? Really? Wow.
  • VimFuegoVimFuego Frets: 15592
    how do they get the worlds largest tyre into the boxes?
    4reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • mudslide73mudslide73 Frets: 3092
    I share a birthday with Shakira and Gerard Pique (they're married). So if I'd been in the vicinity you never know ;) Knowing my luck I'd have pulled Pique.. :)
  • EricTheWearyEricTheWeary Frets: 16299
    he could certainly plead insanity on that one... :ar!
  • underdogunderdog Frets: 8334
    jd0272;317937" said:
    NO? Really? Wow.
    Really
    http://aboutus.lego.com/en-gb/news-room/2012/june/guiness-world-record-to-the-lego-group/
  • ICBMICBM Frets: 72519
    I share a birthday with King Edward VIII, Alan Turing, Stuart Sutcliffe, KT Tunstall and Maggie Philbin - among others who I found when I looked it up, including Adam Faith, Colin Montgomerie and Zinedine Zidane.
  • TTonyTTony Frets: 27649
    Edit - I once laid some laminate flooring, found it was duff, ripped it up, took it all back to Homebase, exchanged it for new flooring, laid that, decided it was the wrong colour, ripped it up and threw it away, bought some new flooring, and laid that. Then the missus decided she wanted carpet instead.
    So the you laid ...
    ... the carpet, presumably?
  • richardhomerrichardhomer Frets: 24843
    ICBM;317998" said:
    mudslide73 said:I share a birthday with Shakira and Gerard Pique (they're married).I share a birthday with King Edward VIII, Alan Turing, Stuart Sutcliffe, KT Tunstall and Maggie Philbin - among others who I found when I looked it up, including Adam Faith, Colin Montgomerie and Zinedine Zidane.
    Elton John and Aretha Franklin here.... (Not the same year!)
  • HootsmonHootsmon Frets: 15980
    john McLaughlin and ken barlow are the same cat
    tae be or not tae be
    standing on the top of mount Everest one can see the arc of the earth
  • mellowsunmellowsun Frets: 2422
    There's more harmful bacteria on your keyboard than on your toilet seat.
    Also, Everest is not the tallest mountain on Earth.
    Mauna Kea (the highest peak in the Hawaiian islands) is. It's just that two-thirds of it is under the Pacific Ocean.
  • FosterFoster Frets: 1100
    When my uncle laid the laminate flooring in our kitchen he opened the 3rd box (having laid boxes 1 and 2 previously), cut the flooring to size and holes for the radiator pipes to fit around around, laid the flooring and realised he had picked up the wrong colour by mistake.
    He then removed the wrong colour flooring, put it back in the box, shoved an untouched plank of flooring to the front of the box, took it back to B&Q and swapped it for the right colour.
    We all had a good giggle at the idea of someone opening their pack of laminate flooring to find it pre-cut to fit their kitchen :P
  • chrispy108chrispy108 Frets: 2336
    And as the Earth isn't round, Everest also isn't the furthest point from the surface of the Earth. The summit of Chimborazo in Ecuador is 2,168m further than Everest, nearly a quarter of Everest's height above sea-level.
    Yeah, you might want to try retyping that...
    The earth could be any shape if you're only bothered about the mountain being the furthest point from the surface of the Earth. It could even be the shape of a string of sausages.
    Actually thinking on it, it's not possible for any mountain to hold the title of 'furthest point from the surface of the Earth'. Since you would have to start counting from the summit of the mountain - they are all equally the same height of 0mm.
    5reaction image LOL 0reaction image Wow! 1reaction image Wisdom
    I think he means from the *centre* of the Earth.
  • BellycasterBellycaster Frets: 5863
    I'm glad I play Guitar then ;-)
    Ok, here we go. the last execution in France using the Guillotine, was in September 1977.
    :-O
    Only a Fool Would Say That.
    Doh! Indeed I do. I blame the head-cold I've got, but it's probably just general incompetence :(
