Bandcamp
Spotify, Apple et al
I have a mate who worked for Britannia Row sound company. He swears blind that when they did AC/DCs sound at Hammersmith that Angus & Malcolm used no amps and in fact everything is piped of to direct units. Although I have no reason to doubt him I really find it hard to swallow.
Bandcamp
I'm not trying to argue, but I'm sure Angus said he tried a Wah, and sounded like all the other guitarists in Australia, so to be different went straight to his amp.
Stand me corrected on the wireless unit (having actually viewed the links
LOL. A lot of the time it's not the consumers' fault, either. I remember reading an article recently by a well-known guitarshop (I'm on their mailing list) supposedly debunking bypass myths. One of the first things they said (this is paraphrased, obviously) was, "If you get sound when the pedal is bypassed and you have no power supply or battery connected, this means your pedal is true bypass."
I mean, seriously. It doesn't help that half the efforts to debunk all the myths are written by people with little more clue than those spreading the myths. I very nearly left an indignant response to the article but they wanted your email address and name etc. alongside your reply, which I'm paranoid about. )
So if people can't even get that, how are they gonna get about the different types of switches? Or about relays etc.- which would be one of the ways to implement soft-switching with true bypass, right? And which need power... unless it'd still work when bypassed without power? I actually don't know for sure... )
But to your last point, I agree completely that the correct way to do things is the correct way to do things, regardless of what some chancers do, but at the same time if you're not capable of making the thing yourself you sort of have to live in the real world too, and realise that there are some chancers about and sometimes do things to minimise your chances of getting taken for a ride by those chancers...
EDIT: interestingly, you mentioned about mechanical switches- does that include other switches on the pedal? I know in my (limited compared to yours) experience those wee switches are prone to breaking, too. And the visual sound route 808 has one of those wee switches on it... maybe it's a different type of switch, I dunno. And I suppose they could claim it's likely to be used less than the footswitch. But still.
I remember the time when we used to connect half a dozen pedals (more in my case), often with cheap leads, stick them on a diy pedalboard and just turn the knobs to get the sounds we wanted.
I remember when Wagon Wheels were <this> big
(a) thanks
and yeah that's the problem with relays... I suppose buffers draw current too, but nowhere near as much.
I guess the other big problem with buffers (which has probably already been mentioned in the thread) is that if you accidentally pull out the power supply, you get no sound- which is as big of a problem as having a true bypass switch fail on you, if you're in a situation where you can't afford to have your sound cut out on you for even a second. Granted the fix is a lot easier ) Whether or not you actually think of the fix in the heat of the moment is another thing, I've had pedals "die" on me (and this is just in a no-pressure home situation) and after 5-10 minutes of frantic troubleshooting, realised that the dc jack had pulled out very slightly >:D<
I suppose you could have a backup battery in the pedal (like alarm clocks do), but then you run the risk of (a) the battery leaking and killing the pedal (that can happen, right?) and (b) accidentally pulling out the power supply and not noticing and then having a dead battery. Again, the latter is an easy enough fix, but it's still probably not good enough if you're playing an important (paying) gig where everything has to be perfect... EDIT: also (c) that now you have a battery in there you have to constantly remember to remove the input jack, which is incredibly annoying and which is the main reason I use a power supply instead of batteries ) Wouldn't that also put extra stress on the jack sockets, constantly pulling jacks in and out? Maybe not if it's made right and you're careful, but then there's that assumption again, that it'll be "made right" and that guitarists will be careful with their equipment... )
I think the big problem is that each method has its own problems, really, and you have to decide which problems are dealbreakers for your own personal situation. That's not to say that some problems aren't worse than others (I'd be the first to agree that I'm not that keen on a method of switching that's known, from the get-go, to be inherently unreliable), or that in an ideal world all pedals would just be "made properly", but at the same time, murphy's law being what it is, what can go wrong probably will, plus it's clearly not an ideal world )
(b) Thanks. And yeah that's what I figured.
(c) Same here. I have a shedload of pedals on the floor and loads of them have buffers in them (and not even necessarily "good" ones). Do as I say, not as I do...
Though, that said, fewer A/D and D/A stages and fewer buffers than on most pedalboards where you'd have a delay and a reverb and possibly some sort of modulation doohickey.
