0000 Grade Steel Wool
  • IamnobodyIamnobody Frets: 6907
    edited September 2014
    fretfinder;347748" said:
    jd0272 said:
    Google........
    Wisdom duly awarded. Isn't that what everyone tries first...? Although I guess if they did, we wouldn't have nearly as many interesting questions on here!  :)
    Of course I googled it first. And I found it really cheap on eBay first. But, I hoped a large store would stock it so I could walk in yesterday/today rather than wait for postage.
    There is a decorating centre near where I work so I will try there out of interest - thanks to some suggestions - so it is worth asking these things.
    Previously known as stevebrum
  • nickp;347751" said:
    i cleaned my LP for the first time in 12 years.  makes hell of a difference!!
    watched a good you tube video
    then cleaned using
    credit card first, then wire woolmasked up pups per sambostar's suggestionthen did frets after masking the fretboard all the way up
    That's the process I'll be following. It's got 20 years of someone else's fretboard muck at the moment.
    I usually just use a very slightly damp cloth, elbow grease and Lem oil but thought I'd try this method first.
  • CorvusCorvus Frets: 2942
    You can use Scotchbrite and probably other mesh pads, they come in various grades - no stray bits to stuck to magnets or go rusty etc.
  • OilCityPickupsOilCityPickups Frets: 10675
    Use masking tape to cover your pickups or you will f--k them up badly .... especially open humbuckers. These days I only use non ferrous abrasives like Mirlon on fully assembled guitars.
    Hmmm two more ideas thrown into the mix. Cheers chaps! I'm confused now :-S I see the caution in avoiding the metal getting into the pickups etc.
    Should've said Scotchbrite comes in different grades, light grey's a fine grade. There's some coarse angry bastard grades but I forget the colours... Even with the fine grades it's prob best skip around plastic inlays.
  • 57Deluxe57Deluxe Frets: 7344
    In the high winds of Winter, one dark night the hand of destiny took my motorbike over off of its stand! As such some grazing occurred to the chrome exhaust... I just had to attack it with fine W&D as to all onlookers would look like the bike has been down and as such the rider must be a right plonker...
    I applied Vaseline to the W&D and pipe and went at it... surprisingly it did improve things but I have months of rubbing away to go probbo and will never be perfect.
    So my tip - APPLY LUBE!
    <Vintage BOSS Upgrades>
    Life tips as well!
    Believe me, friction won't be a problem I won't be sliding up and down the fretboard like someone who can actually play...
    Mirlon is simply another brand name of Scotchbrite type material
