Assuming a Deluxe Reverb type amp.
1. MXR Dyna Comp, which some kind of mod done to make it less hissy, or something which does the Dyna Comp sound without the hiss, doesn't have to be MXR. Effectively use as a boost with some compression to even out my playing. Either to boost my drive sound into madness, or to give my clean bit more jangle
2. Digitech Whammy DT. For the usual Whammy octave up and down stuff but also that lovely Detune chorus thing
3. Boss FZ2, or whichever one it is the Behringer Super Fuzz is a copy of
4. Origin Effects Magma 57 or Deluxe 61, I think either would be fine. Slight preference for the very low settings of the vibrato on the Magma, but the normal trem on the Deluxe sounds useful also at more choppy settings. Two pedals in one, so kind of leaves my last slot free for something other than trem, and assuming the Deluxe Reverb amp I'd have the footswitch for reverb and trem on the amp anyway right?
5. Electro Harmonix POG 2. Presets saved for the White Stripes Blue Orchid type octave stuff, but also a preset for something more organ like maybe with volume swells
soundcloud.com/thecolourbox-1
So, this minus some pedals
Keeley Compressor
Xotic EP Boost
OCD V1.4
Zoom MS-70 CDR
Keeley Halo
1. TC Polytune
2. Keely Compressor Plus
3. PC Tim V3
4. TC SCF
5. TC Hall of Fame 2
Into 633 Dragonfly RT
Can't see any reason to change anything in the foreseeable future.
Well, it does have five pedals… four footswitches and an expression pedal .
Whammy V
Ibanez 850 Overdrive
T-Rex Mudhoney
Maestro Comet Chorus
Boss RV 3 Delay / Reverb
I’ve no idea quite how my interest gets piqued to try certain stuff and not others but that’s a board I’d like to try out. No doubt in 6 months that list will be completely different.
EQD Night Wire (doing harmonic trem, phaser impressions and auto-wah)
Proco Lil Rat
Empress Germ Drive
Red Panda Particle
EQD Disaster Transport Sr.
(Swapping the Night Wire out for an EQD Levitation for washed out shoegaze fun...)
Dream board, I'd very much like to try...
Hmmm, this is going to take some time actually, I'll come back.
Keeley Compressor +
Nordvang '83 Drive
Wampler Terraform
TC Flashback 2
EHX Oceans 11
Formula B Mini Bender
Jam Pedals Tubedreamer 88
Jam Waterfall Chorus
Jam Delay Llama
Crazy Tube Circuits White Whale
It actually has a Korg Mini Pitchblack on there but I can use a clip-on if I'm only allowed 5.
That is technically my mini(ish)-board but if I was to rearrange my pedals from my big board I would go with
Analogman Sunlion
Hudson Broadcast 24V (although this one would get switched around a lot)
Analogman ARDLX Delay
Anasounds Element
Walrus Monument
So, posh versions of those! Maybe a big box delay like the RE 202 and I could have a phaser as well.
Diamond Compressor
Boss OD-3
Mooer CE-2 clone./ Mooer Electric Mistress clone (depending on whether I'm feeling more like the Smiths or the Cure)
El Capistan
Flint
Covers pretty much everything I want - the harmonic trem in the Flint doubles as a sort of phaser, and El Capistan covers lo-fi sounds and messed up chorus sounds if necessary.
Korg Tuner
Old Blood Noise - Reflector (wierd chorusy thing)
KMA - Astrospurt phaser
Thorpy - Warthog
Homebuilt stripboard Tremulus Lune tremolo.
If the tuner isnt one of the five, then either a MXR Carbon Copy or Redbeard HairySquid....
Tuner > Drybell Unit 67 > SD1 > DC2w > SA Collider
