I'm making guitar number 7 - Finished!
  • PeteCPeteC Frets: 409
    Good progress -
    shaping up very well !
  • Following this with real interest @axisus, looks like a great project. Love build threads and I'm in awe of you guys who can build guitars from scratch. Keep the photos coming. :-)
  • SteveFSteveF Frets: 539
    Looks good.  Can't wait to see this one.
    I'm interested in how you did the truss access.  I'm going to have to drill a hole once I have done the transition and hope I do it in the right place but your way looks much more reliable.
  • DiscoStuDiscoStu Frets: 5565
    axisus said:
    Fuck yeah!
  • axisusaxisus Frets: 28347
    Once I have taken the headstock down to the right depth I just rout the truss rod channel all the way out. This means that I can check the rod is in the right place before glueing the fretboard on.
    Weekend efforts
    Router plus template to sort the body shape
    First practice at f-hole - complete fail (using my dads scroll saw)
    Second go much better (drilled holes, used dremel then sandpaper and files)
    Made a P90 template
    A quick shot of my messy indoor space, not a great work area!
    A quick mock-up in  my luxurious outdoor space
    A bit of night time body chambering - first steps.
  • NeilybobNeilybob Frets: 823
    wow this looks amazing!
    Great progress :) this is going to be so cool
    A day off work so I got some more sorted.
    Tidied up the chambers. I just did it freehand as none of it will show for the final guitar
    Glued the fretbpard on to the neck
    Routed the pickup holes, then measuring for trem placement.
    Taking out the wood for the trem with a forstner bit
    Tidied up on the front
    and also sorted on the back
    The top feels a tad weak around the f hole, so I'm going to add a strengthening bit. This is a rough attempt, but as it won't be seen I may just use this for the final thing.
  • Mate you’re really clever it’s going to look amazing
  • WezVWezV Frets: 16801
    The routing looks very tidy, especially consdering it was done free hand... but I would consider adding a block back where the strap button goes.
    It might not need it, but better safe than sorry
    edited August 2023
    I meant to leave that bit in, but I was routing and went straight through without thinking! You are right I should add a bit back in, good call, thanks.
    Also - not everything was freehand routing, just the pockets to lighten the body. The 'neat' bits had templates!
  • BigMonkaBigMonka Frets: 1783
    The guitar's looking great!
    But I also want to know about the Beetle under the tarp!
    Ahh yes, oldest son who no longer lives with us told me a few years ago that he'd bought a Beetle and he needed to keep it at our house!  It's an old pain in the ass rust bucket, but he loves it and is over most Saturdays doing something to it. Major operations as well, not just fannying around. The engine is currently in pieces in our garage.
    Stuff from the past few days ...
    swapped to plastic for my f-hole strengthening bit
    Cut out for battery box
    Sprayed rout for f-hole before glueing top on
    Glueing first half of top
    Routed the top holes after
    And second half the next day
    Radiusing the fretboard, always a long old job
    widening the tops of the tuner holes for the ferrules.
    Knocked up a quick jig to aid radiusing
    Made a template for trem posts
