Furch Red (NGD)
13»
  • ShadowShadow Frets: 72
    The other end of the scale to your Red, but I haven't noticed the nut on my Blue OM-CM being loose.
  • droflufdrofluf Frets: 3730
    The guitar tech I use advised a small drop of superglue - that was on the guitar I'd built from a kit and was of, shall we say, slightly lower build quality than your Furch
  • TanninTannin Frets: 5501
    ^We really, really need a LOLwiz! :)
  • ditchboyditchboy Frets: 303
    I’d be contacting Furch to make doubley sure.
    edited November 2023
    ^ Yes, why not do that? I sent them an email, it will be interesting to see what they say.
    I'd have been perfectly happy to take my friendly local luthier's advice - hell, if it needed service under warranty, he'd almost certainly be the chap they'd tell me to take it to seeing as he's an authorised repairer for Maton, Fender, and various others. But why not ask anyway?
    Had a nice reply from Furch service, very prompt. They say that both the nut and saddle are free-floating by design.
    "So each time you restring make sure not to lose the part, and before there is too much tension guide it in place to be centered. So don't worry to restring the guitar now. :-)"
    I guess I can get used to that. Maybe I won't worry about gluing it in now.
    I wonder what their logic is in doing that?
    I'd glue it in myself. Or get your tech to do it of course.
    I've been impressed with their level of customer service - I asked what the bridge pin size was because I wanted to replace the plastic bridge pins on my Little Jane with ebony one and they sent me a set FOC
  • Dave_McDave_Mc Frets: 2360
    No idea, it is quite strange, but at least it's deliberate and not a fault. :)
    Good to know! I’d probably just leave it as it is now if that’s the design, it seems slightly unusual but they know a thing or two about guitars so I’d trust their judgement.
  • SoupmanSoupman Frets: 237
    Only advantage I can see is if the nut needs altered in a set-up?
    Not seen that before, but if they say it's deliberate, well that'd do me!
