My first Jazzmaster build
  • LebarqueLebarque Frets: 3888
    edited December 2023
    impmann said:
    To shim or not to shim?
    The ruler is about 10mm above the pickguard, in line with the bridge posts.
    Shim. But you won't need more than 0.5deg
    Use the StewMac ones, rather than bits of card. Much better, and will give a proper gradual slope kicking the neck back.
    I got the 3-pack of StewMac shims. Sanded down the shallowest one to fit and...it wasn't steep enough. Now I don't know whether to try the middle one or steepest. Should've tried the middle one first doh!
    It's got a TOM bridge, but the neck pocket isn't angled grrrr
  • djspecialistdjspecialist Frets: 908
    The finished article had its first outing at rehearsal last night, and sounded absolutely phenomenal (even despite my playing!)
    I'm over the moon with it.
    Here's a summary of the ingredients:
    • Body: Alder, from @GSPBASSES ;.
    • Neck: Squier Mascis, from eBay. Frets leveled, crowned and polished by me.
    • Shim: StewMac 0.5 degree.
    • Paint: firemist silver nitro light relic, by @rexter ;.
    • Headstock decal: design by me, printed by Rothko & Frost.
    • Tuners: Kluson Revolution (19:1 ratio, staggered poles)
    • String tree: Gotoh RG30.
    • Nut: Tusq XL. Cut and fitted by @Corvus ;, who also did a top-notch setup.
    • Pickups: Mojo 58-64, overwound bridge, A3 magnets.
    • Wiring by me, following a schematic by ThePearDream on OSG: https://offsetguitars.com/forums/viewtopic.php?f=8&t=110194&start=15#p1539844
    • Pots: CTS (1M log tone, 1M linear vol) from Home of Tone.
    • Switchcraft toggle, slider and jack, from Home of Tone.
    • DP3T toggle, from DigiKey.
    • Pickguard: 3-ply parchment, from TinyTone, based on a custom template I drew up.
    • Bridge: Staytrem 9.5 inch.
    • Thimbles: Mastery, purchased here.
    • Trem: Fender AVRI, from eBay.
    • Arm and collet: Staytrem, purchased here.
    Trading feedback | FS: Nothing right now
    JM build | Pedalboard plans
  • SporkySporky Frets: 28573
    That looks ace.
  • Looks great, but it’s not helping my Jazzmaster GAS!
  • can I just ask (because I've never understood this) why the bridge is on backwards?
  • GSPBASSESGSPBASSES Frets: 2351
    edited December 2023 tFB Trader
    @djspecialist  looks really good, always like to see my kit bodies in their finished form.
    If anyone's interested, I have a fully chambered with an F hole all the body curves Jazzmaster. Not quite finished yet, workshop closed till the end of January, should have it finished early February.
    Good question - I hadn't noticed. Any idea @Corvus ?
    GSPBASSES said: @djspecialist  looks really good, always like to see my kit bodies in their finished form.Thanks Graham, the body is lovely - light and resonant. Now I really must not keep looking at that chambered one ...
  • CorvusCorvus Frets: 2929
    @djspecialist just to annoy the offset purists ;) not really - didn't think of a "right" way as functionally it makes zero odds, probably went for easiest access to the screws. Like ABR1 and Nashville are traditionally opposite ways round, but either way works fine. More'n happy to swap it round if you like, I know how these things can stick out at you kind of thing - I'm generally lurking about the place over the xmas time, catching up on my own neglected things.
    Either way this is a nice thing here, it looks great and sounds excellent. Good work on the frets too.
