What's better than a RAT?
  • Amusingly when I saw the thread title my brain immediately went to "two RATS" so i opened the thread to make that joke.
    Its sad when the OP sinks your funnyship before you've even started :-(
    Aww, sorry - I’ll let you make the pun when I buy the inevitable third RAT then…
  • ICBMICBM Frets: 72653
    I was tempted to say the Ibanez Fat Cat - which is basically a Rat copy with buffered switching - but to me it doesn't sound quite as good, a lot of the circuit values are different and it doesn't have the same character.
  • Deco
  • thomasw88thomasw88 Frets: 2335
    Almost every pedal ever made is better than a Rat.
    Not owning any pedals at all is better than owning 2 Rats.
    you wrong..
    Heh - I always forget about the Warthog for some reason! I should probably try one…
    It's REALLY good...
    I thought it was a bit meh tbh.    Much preferred my old rat2, and a newer one that had been modded by some clever chap.
    The rat is simply glorious.  I have had one on my main board for around 15 years now and I've tried to replace it with dozens of similar(ish) pedals but it's seen them all off.
  • I keep changing my mind about RATs.
    I've got one of the "desirable" 90s ones and every timeI use it I change my mind about whether I like it or not. Very mood dependent!
    I keep thinking about how to incorporate a "2 RATS 1 cup" gag into this thread and I'm still failing.
  • jca74jca74 Frets: 356
    A filligree siberian hamster...
  • Ira from Yo La Tengo is a two-RAT man.
  • timbuk02timbuk02 Frets: 273
    Has anyone tried the TC Magus Pro - the small one with toggle to give you three version options?
  • Crazed_FandangoCrazed_Fandango Frets: 62
    edited December 2023
    I've never owned a rat.  The closest I came is the V1 Warthog, which sounded amazing in my old Fender HRDiii, but seemed to lose a bit through my Victory. I've tried a TateFX clone, which sounded okay.
    The lack of volume clean up on Rats, kind of makes it less appealing. And the size of them.
    Don't let your mind post toastee - like a lot of my friends did!
    Ive got one. All 3 settings sound good. Not compared it to a rat but its great for 50 quid.
    I can't remember if he stacks them or uses one for each amp. Any ideas?
  • distresseddistressed Frets: 549
    I've seen/heard stacking live.
    I think this is the case in that KEXP video I posted.
    I believe Pete Holstrom (spelling?) From Dandy Warhol's is also in that camp. Maybe Thom Yorke during Radiohead's earlier stuff too?
  • darthed1981darthed1981 Frets: 11889
    I was going to say an Otter.
    Cuter
    Bigger
    Make Cuter Noises
    Otters rule.
    4reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • chromatunachromatuna Frets: 374
    Recently acquired my first ever Rat style pedal in the form of a Chicago Stompworks Mr Vermin and jolly good it is too. At medium to higher gain it’s classic rock in a box and at low gain a nice edge of breakup kind of thing. I like what it does more than many overdrives I have owned such as TS variants, OCD, FET drives Nobels and so on, somehow less pedal sounding.
    This is the truth from hillbilly guitars!
  • A Mongoose…
    I didn't rate it - struggled to get from it what it usually takes 5 seconds to get from a proper RAT. Pot values maybe, or just the circuit in general with some sort of modification to make up for the different chip? I forget how they marketed it.
    I bet there are plenty of better options for a little more money!
