https://www.ebay.co.uk/itm/115689299335?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=o9I6saMNQrq&sssrc=4429486&ssuid=hyIfLKwFTie&var=&widget_ver=artemis&media=COPY
But not the price tag. Haha.
Maybe Keeley red drive would be good, too. Give you lots options from boost to drive pedal.
But having more options with the full-sized one is good, I think I'd be using it as different types of boost, one for solos to bring the level up and one on a clean sound with a single coil guitar to kick in more input before the amp.
Although I do get confused with too many knobs lol so the least amount of messing around with twiddling about the better.
Like on a lot of mini pedals the connectors could be better it helps if the pedal is well secured to your board.
Here's a suggestion. There's a bunch of King of Tone clones around for very reasonable money (bought one because yes I am on the waiting list) that do a pretty good job. I've got the Demon FX version although I suspect they are all the same regardless of whatever moniker is on the front. Anyway it's a good, cost-effective way to play about with a dual boost/OD and the internal dip switch options give quite a range to play about with.
