Reversing a Soundport
I have seen a classical guitar for sale that has what appears to be a DIY sound port.I'm awaiting a response from the seller to see if it has any reinforcement, was it done professionally (it doesn't look it) etc.What I'd like to know is, can a skilled luthier reverse the process? i.e. fit a close matching piece of circular, curved indian rosewood and plug the hole in an aestethically pleasing way.Has anyone on here attempted it.The guitar is a traditional classical guitar some 30 years old and whilst a sound hole may improve the sound/volume to the player ,it's not to my taste.TIA for any enlightenment and apologies if it's a no no and stupid question.
  • TTonyTTony Frets: 27674
    It wouldn't be an easy task to do structurally (matching the shape and curve), so expect expensive, unless it was a simple bodge job with (eg) a piece of thin veneer.
    And what might be "aesthetically pleasing" to whoever took on the task might not tick your box - so there's a risk that the outcome wouldn't be what you'd hope for.
    Unless it was particularly valuable and worthy of reinstatement, I'd move on and find another ...
  • Winny_PoohWinny_Pooh Frets: 7798
    It will be visible no matter how good the luthier is. It's extremely hard to match wood under clear, plus the patch would be on a curved surface and the port would need rerouting (again, on a curved surface) or carving.
  • WezVWezV Frets: 16778
    invisible likely won't happen without a solid finish.
    It would either need a decorative fix, or maybe a removable port cover is a better solution.  I'd avoid if it looks dodgy already
  • Thanks for your replies. The owner has since got back to me to say the port was professionally done by his father who was a luthier. It’s a middle to top end instrument ( solid woods) at a great price so I might arrange to view it. I wasn’t aware that you could get sound port covers which seems a good compromise.My intuition was telling me a patch or filler would be a tricky and expensive process and I’m grateful for your input.
  • MARVlNMARVlN Frets: 108
    If it helps at all, this video gives an idea of the process of blocking up a sound port (and is a good relaxing watch anyway - Ted's great):
    Very interesting, would definitely be doable in the right hands. Thanks for posting, I’ve watched a few guitar tech/ restoration videos and always find them interesting. Pity this one had a bad ending
