https://news.sky.com/story/footage-shows-moment-flames-shoot-out-of-boeing-747-13051697
747s are safe. It probably wouldn't even have made the news at the moment if it wasn't a Boeing aircraft.
Insider saying that the door plug had to be opened during production to replace a damaged door seal, but the official build records show the door was never opened, so no further check was created to ensure the work had been completed correctly.
https://www.theguardian.com/business/2024/jan/24/delta-air-lines-plane-nose-wheel-falls-off
Ironic considering the 757 is the aircraft Boeing *really* need to reintroduce instead of the Max. (If they don’t have time for a brand new design.)
The new 777, when it finally, finally arrives, absolutely must succeed or Boeing is rooted. They won't go out of business because the US government will hand them free lunches (especially via military contracts) but they may end up a mere shadow of the mighty company that was.
Turns out there is an H in Haych! ~ Sporky
Bit of trading feedback here.
Always keep your seatbelt buckled.
Publishing "AIRLINER PLUMMETS FROM SKY!! PASSENGERS FEAR FOR THEIR LIVES!! PILOT SAYS "I DON'T KNOW WHAT HAPPENED!!" gets more clicks than "Airliner hits air pocket, several passengers get minor injuries".
Main point there is a big +1 to keeping your seatbelt on!!
Authorities in Chile and New Zealand are investigating and will no doubt report the result. But it seems perfectly clear that it wasn't turbulence (a so-called "air pocket") but rather a fault with the control system.
Edit: But of course your general point is a fair one, even though in this instance it happens to be incorrect. And once a particular focus is brought to their attention (an aircraft type, a make, a technical feature like fly-by-wire or sidesticks, or most of all an airline) they hammer relentlessly at it, reporting any minor semi-routine incident at Panic Factor 9. Much of the time these mainstream press reports are written by general-duties journalists who haven't got a bloody clue about aviation. Just last month I noticed a breathless report in some major newspaper or other talking about "wing flaps". Oh, FFS - if you don't even know what flaps are, you should be ringing up head office to get somebody better educated out to write the story.
Minor event lol, buying a car is a minor event, not a 5 year+ ordeal. 50 people in hospital from a flight with instruments going blank isn't an air pocket.
It's surprising they even fly at all.
I did Aero Eng at uni, and it still fills me with wonder how they fly.
