Recommended overdrive/boost pedal
13»
  • BarquentineBarquentine Frets: 288
    Following with interest. I find when using single coil guitars into my small 5w Marshall DSL it lacks a bit of punch for stuff like solos and cleans.
    Thinking of getting either the MXR Micro Amp or the TC Spark one mentioned above. Anyone tried those?
    The larger TC Spark is wonderful. I set my amp to clean-ish/edge of break-up and use the Spark to push it a bit further. On the clean setting with all controls at noon it just gives a bigger, fuller sound without messing with your basic tone. You can also set it for a mid boost or a 'fat' boost. Very versatile. One pedal I will never part with and pretty cheap.
  • TheBigDipperTheBigDipper Frets: 4815
    I like mine a lot, too. Versatile - but you have to pick your use case. Like this, pushing an amp that's on edge of breakup into breakup, it's great. Fat mode or Mid mode. It's how I use mine at the moment, too. Very organic.
  • hoopshoops Frets: 227
    Mad Prof Twimble. Blatant advert for my ad in classifieds. Great pedal tho.
  • LestratcasterLestratcaster Frets: 1095
    Yeah I went for the full-sized one in the end. Not had alot of time to play with it at the moment but when I had a quick go last week it sounded good. Just kicks more input into the amp especially on my single coil Telecaster. Mid is great for solos so a good one to kick on for that moment in a song.
