I have done a search but cant find anything. I wondered what peoples preferences are towards getting a solo boost? I currently use a boost in the loop but since getting my Jubilee I no longer have the need for my passive attenuator in front of my amp for a quick clean setting. I was wondering whether putting this in the loop, setting my amps volume to my solo level and use the attenuator as a rhythm cut would be better? Is it safe to do this? Is it safer than boosting the loop level? Which is the best option on the amp?
The only reservation I have is that it uses a metal switch instead of the boss type buffered switch. I used to have an LPB-1 in the loop and this made a loud pop - will the passive attenuator do this? Its a Vein-Tap Leech
Check out my band
Coral Snake if you like original hard rock!
http://www.musicradar.com/reviews/guitars/homebrew-electronics-detox-eq-603398
