2015 Challenge: WezV Harley Benton mini guitars
  • TTonyTTony Frets: 27646
    WezV said:
    I have just veneered the mini-RG using @Andyjr1515 's method from last years challenge
    He's not daft, that @Andyjr1515
    You'll make me blush, @WezV & @TTony    ;)
    By the way, looks great  =D>
  • WezVWezV Frets: 16742
    edited February 2015
    credit where its due fella.   I have tried a few different methods before and never got results I could live with.
    best I achieved was with a large clamping caul made from a sink cutout of worktop and a hell of a lot of clamps.  I have tried the sheets of iron on glue as well which didn't work as well as the rollered on evostick
    I am a bit worried about routing the binding slot, but if it works well it should give a very neat edge.  if it doesn't i will try reveneering with the slot already done and trimming back to that edge instead
    the upside of all those failed attempts is I have quite a bit of nice veneer not doing anything
  • dindudedindude Frets: 8539
    The mini Rickenbacker looks fantastic in the mock up.
    Hi, @WezV
    I've never tried a binding slot on a self-veneered surface, but I do route inlays through it (see below - and this was a very brittle veneer) and that works just fine.  Might be worth trialling it on a piece of scrap wood...
    its not just the veneer I am worried about chipping... I am trying to leave the back and sides finish pretty much intact too
    just stripped and veneered the headstock too.
    Excellent - on this kind of build it adds a certain je ne sais pas...   :)
    just found another small error on the B-stock mini-rg.    there is a broken screw still stuck in the back of the headstock
    Just found a slab of african walnut I had forgotten about.   Its not big enough for a proper guitar but it should be just right for shorty.  I have split it in half and glued together for the new body.  I love working with this wood so its nice to find a use for this bit
    and i decided to put some finish on the mini-rg.   I will probably still be binding this but wanted to try staining and sealing first as sometimes the binding glue prevents stain taking properly.... may as well try a different order or operations on this
  • Hertz32Hertz32 Frets: 2248
    Oh man that looks amazing! I would consider a slight burst to it too, but thats just me :)
    'Awibble'
  • That looks fantastic!
  • What did you use as the stain?
    Chestnut spirit stain - also recently used on the moderne build
  • Lovely job. Goes superbly well with that veneer :)
    well, its a bit of a gorefest  - but Its working out quite nice
    Just got my vouchers!!
    Orderd a couple of upgrades for the mini rg. A cheap hardtail bridge based on the hipshot design. It will be strung through the body. Its also getting some abalone dots.
    Then I have a Gibson 500t pickup that's spare so may go in this
  • Looking really good there. You don't waste much time do you. Mine just arrived yesterday. A tele te-30. Quality is better than expected.
    Love that red stain finish. beautiful. In a couple of weeks you're gonna have 2 very happy kids.
