Off to be buildery schooled for the weekend ....
  • RolandRoland Frets: 8754
    I like the name on the headstock. What did you do it with?
  • JalapenoJalapeno Frets: 6398
    decals from Rothko & Frost (pre-ordered)
    Feedback
    Here's a guts shot of the aged @Mojopickups and wiring loom going in
    Feedback
  • Nice work, Jal. Loving that headstock logo, too. :)
    If you must have sex with a frog, wear a condom. If you want the frog to have fun, rib it.
  • jd0272jd0272 Frets: 3867
    Another Tele is born. Excellent :)
    Of the 12Fret / Guitar Tech Courses' course:
    I really enjoyed it, and James Collins is a great teacher.  Neck profiling, nut cutting (from an massively oversized piece of bone), full setup including truss rod tweaks, soldering in 3 busy and packed 9-5 days.  At no point were we under stress, it is about right for a partscaster build course.  I think they run once a month, and pub opposite is fine (but there is nothing else near by), with a Travelodge and Premier Inn not to far away.
    I'd thoroughly recommend it !
    (Won't bump again, think everyone's seen it who wanted to).
    What next though ... ? ;)
    Feedback
  • MegiiMegii Frets: 1670
    Looks fantastic @Jalapeno - a bit of a Ted Greene influence there maybe? Great job anyway! :)
  • A5D5E5A5D5E5 Frets: 307
    Jalapeno said:
    Sooo ......
    From this pile of bits
    A bit of a shame you used modern bottled water rather than vintage correct water drawn from a well.  Still, looks pretty good despite that.
  • TTonyTTony Frets: 27680
    edited March 2015
    You know the answer to that ...
    [edit]
    I did the 12th fret course as well. I can only echo what you have said. James is a great teacher and very knowledgeable.
  • joeWjoeW Frets: 467
    I did a jazz master on this course with James and it was a great way to get into guitar setups and partscaster builds.  It’s great to have a guitar that you know from the ground up and I still enjoy changing pu’s etc and have since built pedals etc.  James is an excellent luthier, teacher and a great guy too.
    Holy Necro-Bump !
    He is an excellent teacher.
    Feedback
