Line 6 Helix
  • ThorpyFXThorpyFX Frets: 6192
    thorpy6;760848" said:
    ThePrettyDamned said:
    thorpy6;760795" said:The helix gas is not subsiding...... Damn you line 6!!!!
    And with 4 loops, you need to develop at least two more pedals before you truly start running out of options! ;)
    hahahaa and they are already done....... just waiting in the wings.
    Spill the beans you tease!
    @gassage has one of the prototypes....
    Adrian Thorpe MBE | Owner of ThorpyFx Ltd | Email: thorpy@thorpyfx.com | Twitter: @ThorpyFx | Facebook: ThorpyFx Ltd | Website: www.thorpyfx.com
  • monquixotemonquixote Frets: 17647
    edited August 2015 tFB Trader
    Question for @rossyamaha and @digital_igloo
    My band use IEMs. Would I be able to have guitar, mic and iem mix into the helix a mix of all three coming out of the headphones but individual mic and guitar outputs going to the mixing desk?
  • ClarkyClarky Frets: 3261
    I saw that there is a rack Helix and a floor one..
    what's the difference..??
  • Si_Si_ Frets: 384
    Other than a world clock there identical.
    Clarky;761041" said:
    I saw that there is a rack Helix and a floor one..what's the difference..??
    There is a video on the helix website, towards the end the differences are explained, it is mainly just more IO
  • WazmeisterWazmeister Frets: 9573
    I just know I'm gonna buy one of these
    good news everyone, discounted helix to be available 3 - 5 days after launch :-P
  • chrispy108chrispy108 Frets: 2336
    edited August 2015
    It's not much, no extra channels or anything. From the Line 6 FAQ http://line6.com/support/topic/14264-helix-faq/
    What’s the difference between Helix and Helix Rack?
    Along with the Helix Control remote, Helix Rack’s workflow and feature set is virtually identical to that of Helix. Plus you get duplicate expression pedal jacks, a 1/4” analog bypass (buffered) output, AES/EBU in, and Wordclock in with terminator switch.
    I think that having the big screen on the floor might make it easier to use when playing, but obviously lots of bending over etc to tweak.
  • dindudedindude Frets: 8539
    Wow, the boutique pedal industry may as well give up!
  • guitargeek62guitargeek62 Frets: 4144
    edited August 2015
    Another question for @rossyamaha and @digital_igloo
    Is it possible to arrange for a demo of the Helix through a set of Yamaha HS-5//7/s at the demo weekend in Soho?
    I expect that I'll be replacing my Mesa with monitors once my Helix arrives so that I can take full advantage of the modelling and stereo output options for home use. I'd like to get an idea of how it sounds with home studio gear though, as all of the demos I'm hearing/seeing so far are either through high-wattage FRFR systems, or using valve amps.
    Talking of which - @Drew_fx am I right in thinking you use/used to use some Rokit RP's for monitoring at one point?
    Not me mate
  • GassageGassage Frets: 30929
    edited August 2015
    My lips are sealed. Major Thorpe insisted on level 4 security clearance before I test drove it. But if you like low gainers you may be in luck. However will say, genuinely, due to my dads situation, I've not had the chance to play with it like I wanted to but it has great clarity and sparkle.
  • Drew_fx said:
    Not me mate
    Ah okay, must be getting mixed up then. Cheers!
  • Will the Helix do firmware updates?
  • rossyamaharossyamaha Frets: 2459
    @guitargeek62 I don't see that being a major problem at all.
    Absolutely.
  • @guitargeek62 I don't see that being a major problem at all.
    Awesome, cheers!
  • Oh jeez... now I'm thinking of ways to run 4 signal paths into separate monitors for a quadrophonic rig!!!!!
    @rossyamaha Once available, will the Helix replace this forum with a single thread about patches/updates/routing/connectivity?
    Absolutely.
    Are the delays new algo's specifically for the Helix?
