It makes comment #70 seems quite odd in retrospect - https://www.gearslutz.com/board/so-many-guitars-so-little-time/770621-send-klons-3.html
"A new issue and argument arose for me when I was arguing the CLONE squeezing of the Klon circuit into a small enclosure and altering components.
Brian Wampler recently commented that in his discussion with other builders one often overlooked variable of circuit design is the layout. If you just move everything around and squeeze it down often using different same type components and makes, you simply do not have the same circuit. It might sound fine but it is inherently different.
Many of these KLON clones may sound fine and indeed I have seen very unlike circuit pedals sound like a Klon on some settings, but, it is not exact, and it is not an identical mimic of said horse. "
soundcloud.com/thecolourbox-1
Welcome to the forum BTW.
well that's the version I want to see you do! Welcome though, I hope you don't mind the intrigue!
