I'll get the gloves....
apart from a bit when I couldn't work out how to save parameter changes rather than block changes it is working well.
Amps.
Some of the clean and high gain preamps do work quite well but non-master volume amps, like the plexi, lose the power amp distortion which is 99% of the sound that you're after so you'd be as well using the full amp
Ideally a hard case, but it doesn't heed to be heavy duty, looking at the measurements my Pedaltrain PT-1 case may do the trick for now. Ideally it wont be in the case whilst on the floor unless it's a very good fit, the places we play are generally tight on space and I'm hoping I don't need any additional pedals although I'm not sure what's going to replace my MI Crunch Box.
The first stage of my 'plan' is to use the Helix to reproduce my pedalboard, phase-2 will be to replace my amp as well.
Haven't really thought about what next, but I'm sure by the time I've reproduced my current set-up I'll have used about 10% of the Helix's potential
http://www.swanflight.com/line-6-helix-guitar-pedal-flightcase.html
its heavy but that's what bass players are for
