51 P Bass Semi-acoustic: The Bass Fender Forgot to Make
I’m a P bass man. I love the feel, the sound and the look. I’m also fascinated by the original 51/52 P basses where it all started.
It’s a bit like the Telecaster - Fender started there and then produced numerous variants. But unlike the Tele, they never did a Thinline.
What’s the point, you may ask? Well - a semi hollow bass has a distinct character all of it’s own - my ibanez semi hollow sounds really thumpy and deep but also acoustic in tone as well. I really fancied a P that did this.
But Fender never made one. Not properly. So a quick @GSPBASSES conversation later and we were off.
I have had the body & neck for a while and it’s floated to the top of the projects pile now - I’ve gathered all the bits and so it’s time to build!
Here it is when it arrived:
«1345
    I wanted to stay natural with the finish and not hide that grain, and I also fancied a tint, and after a bit of thinking and research I found a nice Danish Oil with an amber tint to it. Hardware will be black, so should go well together.
    Neck will be a good old Tru Oil finish.
    First coat of Danish:
    After some soaking and extra coats, round one was complete:
    Quick trial fit of the bridge just to see:
    Left it overnight to dry ready for round two. Several daubings later and we have a second coat:
    Neck has had two coats of Tru Oil - will need a few more yet, and a slurry sanding, but it’s getting there:
    Whilst on the fretboard stand at the guitar show, I got talking to our neighbours Grainger Guitars.
    This bass has had a real danger of ending up neck heavy, so it’s a cut down headstock, and I’ve ordered Hipshot ultralites. My third remedy was going to be a heavy bridge - Grainger showed me one they had at the show and I bought it - it’s a monster! Will be perfect for the job.
    It’s really well made and superb fit and finish - highly recommended!
    I’m also recycling a few bits - my ACG Finn upgrade released the old harness as a spare - so I’m using it in this one. I have a set of matching knobs from Grainger Guitars as well to go on the pots:
  • martmart Frets: 5205
    That body is looking stunning! And the whole concept is pretty cool - it is a wonder that Fender hasn’t done something like this itself.
    Thanks!
    I’ve never understood why they didn’t do a decent Thinline bass - they’ve skirted around it but not properly. I find the hollow bass sound to be really usable as well.
    Oh well, their loss ;)
  • JonHoskerJonHosker Frets: 398
    Thanks....this is THE bass project I want to copy / following the build with interest.
    Jon
    Jon
    If you need help and or ideas when it comes to yours then just let me know - I’ve done quite a lot of research for this one ;)
  • JalapenoJalapeno Frets: 6403
    Looking fab !
    Feedback
  • WezVWezV Frets: 16832
    are you doing the wetsand on the body too?  it works quite well on Danish oil
    Yes, I’ve built up a finish and I’m going to wet sand the next coat on.
    This is coat 3 and after a bit of drying I’m going to wet sand...
  • This is a spectacular build! Love that bridge too.
    It’s drying quick in this weather!!
    I’ve done a first pass wet and dry slurry sand at 600 and 1200 grit.. you can see the sheen on it now...
    Thanks! I really do recommend Grainger Guitars - brilliant kit and well made (all in the U.K.!!)
    Just make sure you soak your rags in water after, especially in this weather
    Noted.
