I haven't used Rustins grain filler ( but many do) but with all fillers, it is making sure that you sand back to the wood enough if you are using a stain while not sanding all the filler out of the grain! How well the filler takes the stain sometimes depends on the stain as much as the filler. The beauty is that, if it doesn't go completely right the first time, you can just sand it back and try again....most of us have!
Just hoping the neck doesn't look too dark or I'll be taking drastic action to remedy that.
I've decided to simply call it 'Ashcaster'. The decal will be very plain and black.
The neck might be getting re-done today, it's just too dark for my liking. It'll be a hell of a lot of work to get the poly off between the frets without removing them (which isn't an option) but I might have to put the graft in to get what I want.
My hardware has all arrived too from Gavin at Axecaster so I'm a bit excited.
A shed I can only aspire to!
Did you go for their aged hardware? If so, what's it like?
