Can you get hold of them at all? If you can, heat the bit that protrudes with a soldering iron, give it plenty of heat then grip with long nose pliers or similar, the heat should help loosen the screw.....
If not there are special tools available like a tiny hole saw that will cut all round the broken screw allowing removal, then the hole is filled with a wooden plug and redrilled....I dont know the correct name for the tool, someone will be along soon who does...
I did the same fitting a string tree to a Birds eye Maple headstock, made a mess of it, totally gutted...now when I drill for tuer screws etc I drill almost too big for the screw, as they are so soft.....
drilled a 1mm hole next to the screw and it gave enough room to get a pair of strong tweezers in there!... the extra hole is about 3mm deep and has now been filled with some rosewood dust and superglue!...
but yes... at the time my world came crashing to a grinding halt!.
Yeah the candle wax on all screws into hardwood is well worth doing. (Or if like most of us you don't have candles, use a dry bar of soap to scratch some flakes onto the threads.)
http://www.thefretboard.co.uk/discussion/61134/sarge/p1
I'm probably going to buy a set of drill bits going in 0.1mm increments in the near future, so that I can get a really precise fit for the hole. You can buy a set going from 1mm to 6mm quite cheaply on Amazon, for about £25, and that seems to be worth a try.
Ahhhhh ...
HELP !!!!!
Massive cock
No?
Nobody?
Just me then.
JM build | Pedalboard plans
And hello @GloopyJon
• Youtube - https://www.youtube.com/@Goldeneraguitars
Curiously it was the two screws at either end of the run of tuners!.
Glad to hear that your business is going well too!
Its going well yeah, hard work and very much living day to day. Hopefully it’ll be worth it in the end
