HELP!!!!! Massive cock up!.
Whilst fitting the tuner to my lovely new rosewood neck, I have managed to shear two screws off in the decking headstock....
how do do I get these out peeps?
  • paulnb57paulnb57 Frets: 3073
    edited January 2018
    What an utter bastard! I bet you are gutted!
    Can you get hold of them at all? If you can, heat the bit that protrudes with a soldering iron, give it plenty of heat then grip with long nose pliers or similar, the heat should help loosen the screw.....
    If not there are special tools available like a tiny hole saw that will cut all round the broken screw allowing removal, then the hole is filled with a wooden plug and redrilled....I dont know the correct name for the tool, someone will be along soon who does...
    I did the same fitting a string tree to a Birds eye Maple headstock, made a mess of it, totally gutted...now when I drill for tuer screws etc I drill almost too big for the screw, as they are so soft.....
  • poopotpoopot Frets: 9099
    Believe it or not they are out!....
    drilled a 1mm hole next to the screw and it gave enough room to get a pair of strong tweezers in there!... the extra hole is about 3mm deep and has now been filled with some rosewood dust and superglue!...
    but yes... at the time my world came crashing to a grinding halt!.
    0reaction image LOL 5reaction image Wow! 1reaction image Wisdom
    Well done, great save!
  • Good that you managed to get them out.  A bit of candle wax on the screw thread helps to make them go in a bit more easily and less likely to snap when using small screws made of cheese.
  • RavenousRavenous Frets: 1484
    Yeah the candle wax on all screws into hardwood is well worth doing. (Or if like most of us you don't have candles, use a dry bar of soap to scratch some flakes onto the threads.)
  • SargeSarge Frets: 2429
    edited February 2018
    If you have a female partner and you reside within 200 miles of Ikea then you have candles, hundreds and hundreds of bloody candles
    8reaction image LOL 0reaction image Wow! 1reaction image Wisdom
  • Funnily enough, I did exactly the same thing this evening!  One of the screws broke while I was fitting the tuners onto a bass that I'm currently building.  I dug the screw out; fortunately, the mess that I made doesn't matter because I have to add an extra veneer onto the back of the headstock anyway, because I made it too thin.  And I'd put some wax on the screw before screwing it in too.  I hate cheap screws with a vengeance!
    I'm probably going to buy a set of drill bits going in 0.1mm increments in the near future, so that I can get a really precise fit for the hole.  You can buy a set going from 1mm to 6mm quite cheaply on Amazon, for about £25, and that seems to be worth a try.
  • TTonyTTony Frets: 27684
    Wait until you try cheap drill bits!
    Ahhhhh ...
    Try this place https://www.ukdrills.com/hss-drill . They are cheap and have 0.1 increment metric and imperial sizes. I got a range of sizes to drill precise pilot holes from there a while back.
  • Did anyone else chortle at the fact that, scrolling down Recent Discussions on the mobile, the first two lines in the title of this one are
    HELP !!!!!
    Massive cock
    No?
    Nobody?
    Just me then.
  • GoldenEraGuitarsGoldenEraGuitars Frets: 8825
    Glad you got sorted! That’s a nasty one when that happens.
    And hello @GloopyJon ;)
    What really pissed me off was, I went and spent £40 on a decent set of 1mm-10mm drill bits for this build... drill the pilot holes to the exact diameter needed... waxed the screws... one snapped going in and as I was taking the rest off the other snapped...
    Curiously it was the two screws at either end of the run of tuners!.
    Wotcher dude, hope all is well with you!
    All is smashing Jonathon. New workshop nearly sorted and a massive lot of orders to plough through! You’ll need to show off some of your builds off around here. You’re still doing that?
    Yes, I have pictures on my website, www.gloopyguitars.com.  I had a busy day today working on another guitar that isn't on there yet - it's going to be a tele shape but with les paul-style electronics and a flame maple top.  It'll be my first time trying to stain flame maple, so I'm looking forward to that!
    Glad to hear that your business is going well too!
    Excellent, I’ll take a look later on. The staining sounds intriguing. I remember watching  a PRS factory tour episode on YouTube, the guys were applying the stains and it was just incredible watching the maple come to life.
    Its going well yeah, hard work and very much living day to day. Hopefully it’ll be worth it in the end
