Just an uneducated hunch but - headroom and operating voltage, maybe? With my limited experience with running overdrives from 18V or more, I've noticed more '3D-ness' - inside an amp you've got potential for much more than 18V (especially valve amps).
Of course, that could be utter bollocks.
I'm not surprised because:
500volts dc in a Valve amp.
9v dc in a Guitar Pedal
Over the years I've found that transistors sound like transistors, jfets sound like jfets, valves sounds like valves.
I'm a Fender Deluxe Reverb owner and have built many valve amps and pedal circuits.
Depends on the pedal surely?
Example, I like a Marshall Guvnor Mk1 or 2 as an alternative to a dirty amp, but an SD-1 or Bad Monkey as a boost to a dirty amp.
No it doesn't sound like a cranked Marshall, but it does sound like an opamp with led clipping for distortion.
Hmm, I'm torn on this one. For years, I've used solid state amps set clean and got dirt from a variety of pedals. I play in a covers band and this approach gives me a lot of flexibility. Have just got my first proper valve amp though so may well be using amp distortion more...
One of my all time favourite guitarists is David Gilmour and pretty well all his classic lead tones come from dirt pedals into loud and clean HiWatts. The Comfortably Numb lead tone is probably my favourite tone of all time, so it's clearly a recipe that can work.
On the other hand, for straight up hard-rock crunch, it's hard to argue with the AC/DC approach of humbuckers straight into cranked Marshalls....simple set up, huge sound.
yes, but the Guvnor is closer than an SD-1.
Also surely it depends on what volume you play at, and whether you're going into a clean amp, or DI-ing into a PA system.
I do understand what you're saying, as into a clean amp the guvnors (etc) don't have an exact match to a dirty Marshall sound, similar, but not exact.
i like go clean amps...and my current favourite pedals are the Black Arts Pharaoh and the Black Arts Quantum Mystic...yes, the Pharaoh is fuzz, but the Quantum Mystic is distortion, and i've never heard an amp with better dirty channel than this pedal.
Pretty much what midiglitch said, in other words.
I do think you're right though, if you want that kind of sound, amp distortion is the best.
Noise, randomness, ballistic uncertainty.
