If having a plectrum in your mouth ruins them that suggests to me that you are not as at ease with the piece(s) you are playing and that tension means you grip the plectrum too tightly. I would suggest getting to know the song(s) better, even bettr than you know them now, and, in the meantime, trying holding the plectrum between your lips instead of between your teeth.
I think just through wear and tear they also deteriorate quite quickly.
Just wondered before disappearing down another rabbit hole if anyone knows/thinks another make/material may achieve the same but be a bit more robust?
They last a reasonable while - ages if just strumming, but I've noticed I need to bin them after a month or two if I've done a lot of practice involving picking/riff bits as well because the tip rounds out and I get even less accurate than normal.
I've had a couple of Dunlop 46s in the past, I used them for my fluorocarbon-stringed ukulele.
intend to “norm” around Yellow / Green(middle of that range), but this last week which has been very warm in the south east, I’ve been using the thinnest Red and Orange to get a good tone
mainly acoustic this week, but I do the same with electrics too
