Advice re pick/plectrums please.
I favour thin Jim Dunlop picks 46mm shown in photos:
https://i.imgur.com/xPLp5Hc.jpg
https://i.imgur.com/wwapIuY.jpg
I like them because they give a great soft/mellow tone without losing all clarity.
However they unsurprisingly are not that robust and end up mangled very easily, probably made far worse by my bad habit of putting in my mouth whilst picking.
Can any recommend suitable alternatives that will give the same sound/feel whilst being a bit more robust.
Cheers
Jim.
«13
  • Jim, you say you know why you like these plectrums. Apart from encouraging you to experiment with other plectrums I would not want to talk anyone out of using what they know works well for them.
    If having a plectrum in your mouth ruins them that suggests to me that you are not as at ease with the piece(s) you are playing and that tension means you grip the plectrum too tightly. I would suggest getting to know the song(s) better, even bettr than you know them now, and, in the meantime, trying holding the plectrum between your lips instead of between your teeth.
  • Its not what you asked but these thin picks are very weak in tone. Have you considered trying the .88 or 1mm nylons if not an entirely different fuller sounding pick?
    Wise words. However I don’t think it is necessary worry or unease about songs. I think it’s just my destructive nature. I chew/pick my nails as well. Just another annoying habit.
    I think just through wear and tear they also deteriorate quite quickly.
    Just wondered before disappearing down another rabbit hole if anyone knows/thinks another make/material may achieve the same but be a bit more robust?
    I’ll give some a go.
  • SnagsSnags Frets: 5410
    I use the .73mm with acoustics, which seems to be a reasonable balance between robustness, volume, tone, but not being too harsh on the attack compared to a "medium" pick.
    Which make?
  • MellishMellish Frets: 947
    Picks you might like include Dunlop Flex. There's a. 60mm white one. It will give you good volume with a little flexibility. I hear a mellow tone using one but YMMV. Hope this helps :)
    Jim Dunlop, same as yours, just a bit thicker.
    They last a reasonable while - ages if just strumming, but I've noticed I need to bin them after a month or two if I've done a lot of practice involving picking/riff bits as well because the tip rounds out and I get even less accurate than normal.
  • prlgmnrprlgmnr Frets: 3992
    Rest the pick in the corner of your mouth then you don't have to grip it, it just stays there.
    Brilliant. Thanks @Snags.
    I’ll try and cure my bad habits! Thanks
    Thanks - I’ll give them a go.
  • LewyLewy Frets: 4253
    Do you lose a lot of picks? I ask, because if you do then ignore my advice, but there are great very durable picks out there but they're more expensive than your dunlops so you wouldn't want to be buying a lot of them. I don't mean £35-40 BlueChips (although they have their place) but things like Wegen that probably come in at something like a fiver each.
  • MattharrierMattharrier Frets: 454
    edited September 2021
    I use Dunlop Tortex 60s or 71s on electrics, but I prefer a softer pick for acoustic strumming as harder ones are a bit harsh sounding - I use the Tortex 50s, which do obviously wear quicker than a thicker pick, but don't snap like the thin picks I've had. I also have some Ernie Ball thins (only because they glow in the dark and I'm a sucker for pretty much anything that glows in the dark) which are very similar, but I find the tortex last longer.
    I've had a couple of Dunlop 46s in the past, I used them for my fluorocarbon-stringed ukulele.
    I don’t lose them - more wear them out/destroy them !
  • I use Dunlop Tortex 60s or 71s on electrics, but I prefer a softer pick for acoustic strumming as harder ones are a bit harsh sounding - I use the Tortex 50s, which do obviously wear quicker than a thicker pick, but don't snap like the thin picks I've had. I also have some Ernie Ball thins (only because they glow in the dark and I'm a sucker for pretty much anything that glows in the dark) which are very similar, but I find the tortex last longer.
    Will check out the tortes 50s. Thanks
    Well I would definitely check out Wegen then. I've found them very durable and have had some of them years. They also sound good...no scratchiness.
    I’ll check them out. Thanks.
  • sev112sev112 Frets: 2799
    I use a range of Dunlops from red to purple and vary them depending on how the I divdual guitar is sounding that day and the song.
    intend to “norm” around Yellow / Green(middle of that range), but this last week which has been very warm in the south east, I’ve been using the thinnest Red and Orange to get a good tone
    mainly acoustic this week, but I do the same with electrics too
    Thanks. Fascinating.
