That will get you started for less than £50; after that it’s easy to fall into a rabbit hole of interfaces, monitors and phantom power but I’d see how you go with a basic setup and then upgrade if you get bitten by the bug.
A cheap one is Zoom handheld recorder (currently Zoom H4n most popular), SD card into PC, download raw recording to PC, use Audacity freeware to edit a .wav file (sound a bit better than .mp3), name and save file to PC before deleting raw file from PC and SD card, then download to free capacity on SoundCloud (enough for approx 70-80 3 minute .wav files). Then you're on web and available to the World!
A new PC will probably have Bluetooth to connect wirelessly to a cheap Bluetooth speaker. The sound quality on those can be surprisingly good. (avoid the boomy ones). Or you can plug a Bluetooth receiver into any sound system or hifi you have. Modern radios sometimes have Bluetooth reception function too.
Total cost £3-400.
Have fun
Ableton takes about 5 minutes to get started with recording with the online guides. Amp plugins are easy to add once you watch a tutorial (loads of videos can be found via Google).
only £99 for this b-stock unit in their current sale: https://focusrite.com/products/scarlett-2i2-refurbished
Likewise the interface, is their much to choose between? Or, as usual, am I overthinking it?
I would like some speakers too - any recommendations there?
Thank you for assisting a noob!
like everything with monitors you get what you pay for. The more expensive ones will be better built, have more features and possibly a higher sample rate (a loose measure of sound quality). Whether you need that for your home recording is up to you.
https://www.thefretboard.co.uk/discussion/260058/cheap-mics-for-recording#latest
how are you planning to attach the audio interface to your PC (for eg: thunderbolt or USB) as that has a bearing on which you can buy
Regarding the hardware, Id be attaching the interface via USB, and Id also expect to be using the speakers for general PC sound too (e.g. games, Spotify)
I'm not averse to spending a bit of money, but only if it's 'worth it' to do so
Mic is necessary for the first, not the others.
For electro/electric, you connect guitar to PC via an interface, with DAW software running on the PC to capture, record and manipulate the sounds of your playing.
Most DAWs include a range of FX to allow you to "enhance" the raw sound. You can also buy "plugins" for even more capabilities, including amp sims and much much more.
I started with an interface & DAW bundle from Presonus (search Amazon), which I still use (albeit upgraded) many yrs later.
For single person home use, a 2 input interface is enough - eg guitar & mic. You can't really play any more instruments simultaneously - the DAW allows you to record more as separate tracks to (eg) layer your guitars.
There are many, many rabbit holes...
