As well as that it gets slightly nicer brakes.
The Hoodoo is one of the best hardtails under £500
You could have this for two hundred quid......
http://www.thefretboard.co.uk/discussion/83239/carrera-vulcan-mountain-bike#latest
http://www.halfords.com/cycling/bikes/mountain-bikes/boardman-mountain-bike-comp-27-5
I have recently purchased a Hoodoo that is around 4 years old although the previous owner had hardly used it. With a bit of TLC (new chain etc) it is absolutely brilliant!
Took it to a local trail Wednesday and it was superb.
Going to Halfords later to have a look.
I tried an 18" Bantu in the shop and with the seat as low as possible I could just about touch the floor with tip toes on one side. I could stand over the top tube with both feet flat on the ground but my crouch was right on the bar, no clearance at all.
The fella in the shop said that's just as it should be and a 16" frame would be too small but I'm not so sure. They didn't have any 16" frames built that I could try.
Fwiw, I'm 5'7" with a 30" inside leg.
But if you don't have enough standover height, you will loose confidence. So look at being able to stand over the top tube, and having the correct pedal stroke. Sounds like 18" is too big.
As others said, drop you seat for the fun bits, or get a dropper - getting it out the way lets you use your body much more to control the bike.
For the two you posted, the more expensive one has a slightly better fork, , it also avoids Tektro brakes on the Bantu, which are always worth avoiding, unless you like bleeding brakes. Although I'm sure they've improved
Stuff for sale:
OWC Thunderbolt 2 Dock (12 port) & Apple Time Capsule 2TB
Stuff for sale:
Its a Specialized Pitch Sport 2017 model
http://www.bikereplacement.co.uk/p95259/Specialized-Pitch-Sport-275--2017-Mountain-Bike.aspx
Any my thoughts on this vs the Bantu? I don't think I'll realistically be able to stretch to the hoodoo unless they offer more money.
Groupset not great, but all three are a muchness. Reasonable brakes on the Pitch too.
More travel on on the other two, depends what you want. Shorter travel not a bad thing as the stanchions are quite thin.
Go see one in a local dealers and see what you think
Stuff for sale:
16" would be much more like it at your height, I ride 16" frames for MTB's at about 5' 10" with a 31" inside leg and I prefer a slightly smaller frame for "chuckability" and jumps. I do have a long-ish seat tube for riding to and from trails, and drop it down a bit for the fun stuff.
Is Halfords a requirement from the insurance company, or can you buy from a "proper" bike shop?
