My bandmate recently showed me a text exchange between him and a girl he's been on a few dates with, asking for advice as basically they seem to be on a different wavelength with regards to how much texting should be happening between dates, he's the take it slow type and it seems she wants to text all day. There's an age gap, late 20s to early 20s, and I think there is a big difference in expectation and technology usage especially with messaging...
Can't remember the conclusion. I did take part, and could hear differences but my favourites were a fairly even split. I liked the dynamics of the solid state cleans more than valve - solid state reproduces in a very unforgiving way and he was a good player so used it to his advantage.
Which is the point, I guess - picking gear that works for you. I like jtm45 for most stuff and 6505 for the heavy stuff because I find it very easy to sound good with them.
In the first test I couldn't tell which was the real amp.. but when he told me which one was the VST, in all the subsequent tests I could identify the plug-in... but the Kemper was unreal... I just could not tell the difference between it and the real amp in any of the samples..
Anything digital basically. So anything that uses modelling/sampling/digital FX etc. It's all cheap(ish) to buy considering the amazing stuff this technology can do but it really does need to considered disposable. It's SO high tech that even if it is possible to fix it, which it often won't be, the labour charge would need to be so high that it would literally be cheaper to buy a new one. This is the real cost of such high tech..... Whereas pretty much anything analogue can still be repaired even if it's 50+ years old..
Bandcamp
Spotify, Apple et al
Communications satellites still use valves BTW... yes really, even the latest ones, in the form of a travelling wave tube for the transmitter back to earth...
