Line 6 Helix
1151152154156157426
  • fretmeisterfretmeister Frets: 24470
    The modded 2204 is a belter!
  • johnonguitarjohnonguitar Frets: 1243
    YUP!!!
    I'm really loving my Helix now. It gives me butterflies. Bump for Helix 2.0
  • kjdowdkjdowd Frets: 852
    Agreed. There's a noticeable difference all round, imho, and the new models are great.
  • SporkySporky Frets: 28544
    What's the harmonic tremolo do? I am not presently near my Helix.
  • andyozandyoz Frets: 718
    edited July 2016
    I going to stop reading this thread...really don't need any more gear..
    I'm going to tag @andyoz in this thread every day until he buys a helix
    None of us *need* more gear ...
    This is true. I need more gigs!
  • nick79nick79 Frets: 254
    I was thinking exactly the same..... I fear it might be too late for me though
    Just had a go with the 2204 through a l3t I have in the living room (repairing the l3s .. I don't normally have a pa in the living room)
    It sounds epic
    Set up a nice wee patch with the delays and miss on a different path and 3 amps
    The MKIV set up as a clean
    The MK IV channel 2 for crunch
    The 2204 for gain
    Switching via snapshots
    It's pretty amazing for 10 minutes set up
    No, not looking anymore...doh!
    I must get round to trying the Snapshots.
    I've only played with the new amps on guitar so far. Funnily enough for guitar use I probably won't use snapshots. But for silly bass use it could be brilliant.
  • FarleyUKFarleyUK Frets: 2423
    Had the first run out using the snapshots on Saturday at a festival - worked very well indeed! Basically had a main rhythm snapshot, then a solo snapshot with delay, a solo snapshot with delay and octaver, and another snapshot with delay and phase, with a bit of flange. Each of them were programmed by MIDI to my amp to switch channels using the instant midi commands on the Bank/Prog change. No idea how that worked or how I got it working, but it seemed to be fine. Sounded amazing as well!
    edited July 2016
    I like to imagine that Cabicular does actually have a PA in his living room. Wall of subs and tops flying from the ceiling 2204 is awesome.
    Not quite... but still pretty fucked up
    You've got the speaker the wrong way around there. The wires are meant to go inside.
    You're welcome.
    Nightmare!!
    so anyway... Just say that I was possibly considering a no-amp setup... Not that I'm getting rid of my amp... But just for talking sake (I feel like such a sell out wen asking)... And say I was going to get a QSC K series speaker. Would I be better off with two 8 inch ones or a single 12?
    The balloon animal is a nice colour.
    I've generally liked QSC's 10s best, but I was coming at them from the Q-SYS direction.
    The 8s will give wider dispersion and still go plenty deep for guitar. And you'll have stereo.
