And read the manual when you do it. There are buttons to push on setting up.
Will do, it makes my pedalboard look like a museum piece, just quickly tried some effects in to the front of my amp and they do sound very good indeed, immediate thoughts are OMG I'm down a button I'm sure I'll work round it
I personally would like to see more drive pedals and an Xotic EP booster, I always turn on my EP (clone) when I use my telecaster and it just does something magical, smooth's out the top end and beefs it up a bit. I'm sure I could simulate it with an EQ close enough, but you do get used to what you know and an explicit model would be great.
I also don't think the Red Comp is quite as squishy as a real dynacomp or my CS-2, but it's very early days I think the trick may be to just get over what the Helix doesn't do and rejoice all the other stuff it does really well
My main two drives are a Zevex BOR clone for a flubby Plexi tone, and and MI Crunch Box for a hot Rod Marshall tone, not sure any of the drives give me that Ill have to keep looking.
Haven't even tried any of the amp modelling yet
not much use for a footswitch .. Leave it on
I find the OCD is great especially stacked with a low gain tube screamer
i have one button that switches them both on and off
My YouTube Channel
My YouTube Channel
price to match!!
screwed new speakers into the line 6 sub (blew one of the last ones ) programmes all my snapshots
going to play a biker rally tomorrow so expect it all to go horribly wrong !
Which has therefore got me thinking Helix...mainly because I can get on interest free!!
Is there anyone here using one purely FOH with IEM's and do I need to worry about custom IR's etc for live use?
im not ready yet
satchel from steel panther has switched to using an amplifire live
i don't bother with custome IRs
ive tried them but they are more fiddly to deal with and you have less control (Ie you can't change mic)
A good way to select your cabs and mic is to use the hands free editing
that way you can toggle through the cabs and mics while you are playing
tried it pre-preamp in to my amp, post-pre in to a valve power amp, and FRFR and all sound fab!
thats, using one preset and one amp/cab. I've still got a million other options, the Interstate Z and rectifier models sound great.
bearly scratched the surface yet, and I'm blown away, not even looked at the manual . It really is that easy
Tonights office... I'm going direct for the first time with Helix. I hate going direct. This is no different. I suck at it!!
for some weird reason my patch sounded like someone had put a blanket over it. I was expecting to be taking my head off but instead had to global eq the shit out of the top end. I'll never get a hang of this shit!
Thats aweosme man, glad you're enjoying it
