The batteries also drain quite quickly I find. Guess that's the nature of the wireless beast though. I just have to keep reminding myself to buy spares and keep them near the board.
Mine is starting to feel a bit loose on the joint to the jack but all working fine.
I agree the receiver feels a bit plasticky but so far my clumsy feet haven't damaged it.
As John_P says, your comment about battery life is very unusual. Most people are very pleased with how long they last. I did have one customer say it didn't meet the 15 hour but it turned out that he was using zinc oxide batteries which are a little over half the capacity of alkalines. We've had very good feedback on using rechargeables (NiMH) too - you should get over ten hours per charge from a regular set of these but some people have reported getting more like 14 hours.
We have 2 of your units in our band which we both used for the 1st time recently without any issues, my question is ...if we get transmitters and receivers mixed up, what happens?
Our 3rd person is also looking to get one, will 3 working together all be ok?
https://twitter.com/spark240
Reddit r/newmusicreview
Three sets in a typical stage area will be fine. Try to maximise the spacing between the receivers (more than 6 feet is good) to maximise range.
Thanks, Chris.
2 questions:
are you still supply those voltage inverter things for pedal board power supplies?
Is it better to buy direct from you....?
m
We have the polarity inverter cables as a £1.99 accessory that you can order with your set from our website. Note you do need an isolated supply to avoid ground loop noise
Yes please do order direct from us unless you really want to give Amazon twenty quid
Chris
order placed just now. Any chance you could get it in the post today first class? If it arrives tomorrow and can rebuild my pedal board. Isn't that what bank holidays are for? ;-)
We always send orders First Class Signed For as soon as we can. Your set is packed and ready to go. It's not guaranteed but will probably arrive tomorrow.
