So when you want to use just one amp you ignore that extra output and use the output on the delay.
So guitar goes into your loop switchers, which have all the pedals other than the Mobius and Timeline.
Out of the loop switchers to the splitter. One output of the splitter therefore has everything except the Mobius and Timeline.
The other output of the splitter goes to the Mobius and Timeline. You then use the output of the Timeline for the other amp in two-amp-mode, and for single amp mode.
But you can't have the Mobius before other pedals (apart from the Timeline) in the signal chain, and have it only affect one output from a splitter later in the chain.
However, if the Mobius is before the other pedals (apart from the Timeline) then you cannot have one output that includes the Mobius and one that doesn't, unless the latter also doesn't include all the other pedals.
Wireless receiver into Mobius - LEFT IN
Mobius - RIGHT IN goes into the output of the DPC-8EZ
Mobius - LEFT OUT goes into the input of the DPC-8EZ
Mobius - RIGHT OUT goes into Timeline's LEFT IN
This was sent from Disaster Area themselves to help me set up:=
http://i1111.photobucket.com/albums/h471/gibby12345/image_zpsgk9tebt3.png
IN THE LOOPS OF DPC-8EZ ARE:-
Loop 1 = WARTHOG
Loop 2 = FUZZ
Loop 3 = CRUISER
The comp is always on so in the DA's always on loop i.e. No Switch for that one
MIDI
DMC-8D connected to DPC-8EZ
DPC-8EZ connected to Mobius MIDI IN
Mobius MIDI OUT connected to Timeline MIDI IN
Then Timeline RIGHT OUT into splitter
Does that make any sense to you @Sporky
Assuming you still want to use the Mobius pre and post, put the splitter between the DPC and the Mobius right input.
Then if the Mobius is Pre, you'll get everything but the TImeline from one amp (using the output of the splitter), and everything plus the Timeline from the other (on the Timeline's right output).
If the Mobius is post, you'll get everything but the Mobius and Timeline from one amp (using the output of the splitter) and everything including the Mobius and Timeline from the other (on the Timeline's right output).
When you're only using one amp, put it on the Timeline's right output and it'll get everything.
The Timeline must not be set 100% wet when you're only using one amp.
That's amazing how you can work this stuff out? Thanks so very much @Sporky . I'll have to get some more cable ordered to change a few things but once arrived I'll get to work.
Just so I'm clear would I NOT get the Timeline into the same amp as the Mobius if it's set to PRE? Is that ok or the norm i.e. Delay in one amp modulation in the other. My brain is warming up again LOL
If the Mobius is set to Post then you'll get modulation and delay in only one.
If you want modulation in both and delay in only one all the time then put the splitter between the Mobius Right out and the Timeline Left in.
In general. Unless you want 100% wet for some reason. Probably you don't. But you might.
R.
Eqd Speaker Cranker clone
At worst I could live with all fx going to one amp and have the other amp dry. But again I want it to work as a one amp scenario too. Don't want to have to pull out patch cables so once once set it more or less stays that way.
In two amp mode, leave the Mobius in Post mode.
In one amp mode you can use the Mobius' pre/post stuff.
Ta-da!
Thanks for all of your help today though
Pre goes to both amps.
Post, if the splitter is between the DPC and Mobius, it goes to just one amp.
