The reason I went for 3rd party instead of stock is simply the stock cabs didn't cover what I wanted. For starters there are no IRs of my favourite cab the Recto 212, and secondly the range of IRs is geared towards a lot of different cabs and speakers when I'd prefer a bunch of SM57, MD421, and Royer 121 positions on the same cab/speaker.
If it was a real cab I'd rather just move the mic than a) change the cab/speaker/mic (which are my options usually with Fractal stock cabs) or b) start faffing with post EQs right away. The Helix cab block does work differently to the Fractal cab block (and allows the tweaks within the block) and I only found out when someone posted a YouTube video in another thread.
Recording is a different thing entirley in my humble opinion
With all the tweaking of cab & Mic selection and in block tweaking of reflection, distanc etc. How important is it to have knowledge of what you're doing?
I know (roughly) what types of cabs and speakers to use for my style of music. But my only experience of micing cabs is moving an SM57 slightly on whatever cab I have at a venue, which often gets knocked mid set, or moved when bands change over.
If I move to helix, Id be creating patches roughly with headphones at home, then tweaking them through PA at practice studio. Is it easy to learn or am I going to be out of my depth with 6,000,000 options?
Which again is a fair point. I've been approaching the IR discussion from a recording standpoint. Personally I still use a real cab with my band. That's the thing with these digital units... there are so many ways to use them that a discussion on the same feature doesn't necessarily mean the same scenario.
Its worth taking some time just to do a bit of background in the different cabs and pics and their characteristics
Alternatively there is no problem with twiddling knobs until you get a noise you like
My favourite way to set up cabs is to use the foot controls to control the parameters `cab `mic selection and then just adjust while I'm playing
Bear in mind that as volume increases, bass and treble increase more noticeable so I always have less at low volumes
I have "gone Helix"
Get my mitts on it next week
What sort of deals can be had on these wee beasties at the shops? I assume there's some wiggle room in the pricing.
but if you manage to buy a used Pre-Brexit one every patch sounds a little better value for money
Hotrox seemed to be the cheapest new (assuming they actually have stock)
Thanks.
Looks like pricing has moved down a bit at a few shops. £1279 was the going rate... now several are offering £1224... and I've found one shop at £1179.
I'll probably wait to see how the Headrush pedal turns out. I guess it's about a month or so to launch.
I'm fairly clued up on cab choices for types of sounds. Mics I'd need to research. good call on using foot controls
on another note - how easy would it be to 're-amp' with the helix? would you still need re-amp boxes or could you just route it cleverly through an interface?
Anyone doing it already?
It outputs a dry signal on ch 8 which you record. You can then route it back in via USB 1 and fiddle about to your hearts content. They have really though that stuff through
That's awesome.
Theres a good diagram of the 8 in / 8 out arrangement on this thread http://line6.com/support/topic/15625-helix-as-audio-interface/ but I don't really understand it. does it mean you need 16 USB ports on your PC, or some sort of interface inbetween?
It actually is a very capable audio interface
It means you could set helix up to reamp 4 stereo tracks on 4 seperate audio paths.
so by default you would set up a guitar track in your DAW (Logic in my case) and set the input to Helix USB 1.
That will give you the left channel of the Helix
Or you can set up a stereo track and use Helix USB 1 and 2 as the input
You would set up another track called Dry Guitar and set the input to Helix USB 8
The other inputs are for other paths or send and return (or pretty much what else you need)
