Line 6 Helix
1200201203205206427
  • sgosdensgosden Frets: 1994
    helix inbound. excited. very.
  • John_AJohn_A Frets: 3775
    Well done sir!!
    Drew_TNBD said:
    have you lasted multiple months with the helix? that must be a record for you ;)
    sgosden said:
    I've purchased a ton of gear recently! Pedals, amps, guitars, etc... But the Helix is my favourite purchase in years!
  • sweepysweepy Frets: 4196
    You won't regret it :)
  • TeetonetalTeetonetal Frets: 7814
    @Drew_TNBD nice to see you back..
    how are you using your helix? FX only in 4cm? or something else?
  • TimmyOTimmyO Frets: 7546
    Picked mine up today.
    Oh my!
    Played through the first bank of presets using good (Audio Technica) studio headphones. There are actually some brilliant patches in there - among the cleaner ones.
    Played around modifying some and assigning expression control (so easy to do)
    Then set up a patch from scratch with stomp-able comp, drive, delay and reverb - sounded fantastic right off the bat.
    Love it
    Red ones are better.
  • SporkySporky Frets: 28664
    Told you.
    I just wish someone had told me about the Helix earlier
  • jaytmonjaytmon Frets: 168
    edited March 2017
    Oh my!
    Love it
    I did pretty much exactly the same. Also set up a patch with two amp sims - clean and dirty - plus effects, connected to laptop via USB and had fun jamming over a number of backing tracks.
    Dodgy playing aside it's the most I've been motivated to play for a while.
    Its flexibility inspires creativity, and I'm a lazy bastard really. Plus it has pretty colours... :)
    All manner of ways really.
    - 4cm for FX only with my real amps. Also controlling the amp channels.
    - Direct recording for stuff at home.
    - Vocal processor for home recording.
    - Sending midi commands to my DAW (Triggering Ableton Live slots for instance)
    - Late night looping with headphones on!
  • stickyfiddlestickyfiddle Frets: 27213
    I'm on holiday next week but my last couple of  "for-sale pedals" are going today so I'll be Helixing once back. Cannot wait!
    Yes. It's the versatility is the beauty of the unit IMO.  I've not done too much with real amps yet. But last weekend I was using it as a vocal processor and interface. Does the job very well.
    I was Intrigued to hear how you were getting on with it as you've also been through a ton of gear and systems, yet helix seems to have stayed a while now.
    I am at a point where it's integral.
    So far the only downside of the Helix is that my fingers are sore from playing.
    I'd like to get a powered PA cab type thing (currently using studio headphones)
    L2 sounds great but pricey
    Yes they look fantastic, but as you say, one of the most expensive options.
    I've heard decent things about the Yamaha DBR and DXR 10" units - bit less fancy and much cheaper.
    Once I've recouped my outlay on the Helix I think I'll take a trip somewhere that does all this stuff (Anderton's maybe) and try a couple of things out.
    While I think about it - things that would make Helix (or any later iteration) even awesomer
    • Bluetooth control via tablet - like the Eventide units.
    • A USB slot to transfer patches from unit to unit (ability to transfer patches from unit to unit, or keep a USB stick with your setup in case it hard resets or somesuch)
    If those sound a bit niche that's because they really do seem to have thought of everything else.
    Last night I started playing with Snapshots - making a solid generic rock sound and comparing a Friedman IR with a tweaked internal cab. I just want to assure myself there is no need to dive down the IR rabbit hole.
    The Bluetooth tablet idea is never going to happen apparantly
    too much information flying between them
    im really looking forward to native so I can design my patches on my studio machine and then upload to the Helix when I fancy
    Helix is sat at home waiting for me. Today has been a loooooong day at work.
    Q. is anyone using a matrix power amp (or similar) to run into stereo cabs?
    Does something like this have a flat EQ section, so that you can use an amp model (pre and power) in the helix without adding an additional power amp characteristic ?
