Helix LT is now available for order. Cut down version - ish.
  • John_AJohn_A Frets: 3775
    Good choice!  There's a guy in Bulgaria on eBay sells a padded case for about £50.  I got a Gator G-mix 12x24 case which is nice and fits really well, has wheels too:
    https://www.studiospares.com/Accessories/Cases-Other/Gator-G-MIX-12X24-Wheeled-Mixer-Case_471190.htm
    Or you can get a custom made flight case for less than the price of the backpack
  • SporkySporky Frets: 28860
    edited April 2017
    Voxman said:
    I'd be interested in comparing the Headrush FX (£899) with both Helix and Helix LT - it must have been a factor in Line 6 bringing out the LT and Helix prices reducing.
    Line6 have said (as, of course, they would) that the LT was in development before the Helix was announced at all.
    The timing and price point may not be coincidental, of course...
  • Musicman20Musicman20 Frets: 2343
    I've been tempted to jump for one of the full fat models but I just LOVE having lots of specialist individual pedals, so I'd probably have fun with the Helix then barely use it...which would be a shame. I'll see how this new model pans out.
  • TeetonetalTeetonetal Frets: 7818
    That was my worry too.
    Reality is that I've ended up using helix and real pedals a lot. Helix just makes me play more. Simplest practice rig ever.
  • stickyfiddlestickyfiddle Frets: 27350
    Cheers. I'll hold off on the case for now. I'm not gigging anyway so it'd only be for storage purposes. Now I need to have a big clearout of the "guitar corner" to make room for the thing!
  • gearaddictgearaddict Frets: 895
    Has anyone seen a comparison of the Helix versus the Pod HD through a power amp into a guitar cab?
    I am pretty tempted by the LT but most of the comparisons I have seen are using the cab sims into a DAW and that's not how I would use it. I'm conscious that people often say the main weakness of the Pod (soundwise) is the cab sims, so into a guitar cab there might be less of a jump in sound quality.
  • fretmeisterfretmeister Frets: 24694
    That's how I use it.
    Helix - power amp - Zilla 2x12 with Creambacks in it.
    Not had amp gas since.
    (and anyway - the stock cab sims are excellent. I've certainly not had a reason to go down the rabbit hole of other IRs)
    I'm planning to use it with my Badcat 90% of the time. Mostly FX into the front end, but will experiment with using it as a preamp too.
  • Has anyone seen a comparison of the Helix versus the Pod HD through a power amp into a guitar cab?
    If you listen to a comparison using the exact same cab IR in a DAW that would be pretty representative of the modeling differences as the unit would be the only variable.
    Starting at 2:30
    Personally I always found the HD500x low end hard to control through a SS power amp and cab.  It was either bassy but boomy/loose in the wrong places, or it was tight but quite thin sounding.  I've not owned a Helix
    Had both the HD500 and now have a Helix, the difference is huge.  The Pod was a great bit of fun to use at home and seemed to get lost in the mix live.  The Helix makes the best sound live I've ever had.  Demos through headphones probably don't show the full story, in use they are miles apart
    Also, a Novation backpack apparently fits and they come up on eBay quite frequently for not a lot of money
    Celeb use spot
    I've owned both
    the Helix is superior in almost everyway
    its a total no brainer
  • @fretmeister... who's that?  Is it you at a recent gig?
  • Guy on the left is John Mayer, no idea on the right.  But as he's got a PRS possibly John Mayer's dentist
    8reaction image LOL 0reaction image Wow! 0reaction image Wisdom
    I've owned both
    There's no almost about it.
    I like to think that Mayer's setup isn't plugged in, and that one Helix is doing all the work for both of them...
    Fairly sure it'll be David Ryan Harris, JM's long-time on/off sideman.
    I'm imagining he's just done the solo to slow dancing in a burning room and hit the 'octave super fuzz + lots of reverb before the fuzz' button by accident instead of the 'tender emotional haunting mids' button on his switcher.  He's about to throw his guitar at his pedalboard.
    The other guy is walking off stage in an 'I told you so' manner.  And is going to go back to dentistry as he's yet to find suitable bandmates
  • Either that or the stage light is really bright and John forgot his sunglasses.
