Getting use to the interface ... does Native sound like the hardware version?
I read a thread on another forum in which people were raving about this ...
http://www.two-notes.com/en/wall-of-sound
When I got my Helix I purchased small pack of Ownhammer IRs (Vox and Deluxe Reverb captures), the Line6 ones, and some free redwirez (I think) ones, oh and the free Celestion one - all mean you'll end up rummaging for ones that suit the tone you're after, so I ended up liking the way that Ownhammer sort out folders of suggested/typically good ones rather than every permutation being equally under your fingertips.
WoS was a bit too easy to select odd combinations of distance/horizontal/mic combination. As an amateur, the ability to find a million ill-advised combinations isn't exactly what I need lol
One of my plans for next time I get a bunch of time to myself is pick out a small handful of good stuff (to my ear) from the files I do have and just stick to those
It's not a direct copy of anything sp can get overlooked - but it's fantastic
That will be awesome.
This is really firing up my recording desires again. Not done it since I had a standalone Yamaha thing with a CD burner in it.
I've written a shitload of songs over the years. Would be nice to get them recorded. One of you tossers will have to do the drums for me though!
Pretty impressed thus far- enough that I'll definitely be buying it.
I could see this actually replacing the Axe FX if it does everything I need it to in the studio.
It looks like it will and it is more flexible than the Axe FX 2, because I don't need to keep a list of patches for reamping later, plus I can plug into different Mic Preamps depending on what I am doing.
Also I can create chains of other plugins more easily than with the Axe FX.
It is a total no-brainer and a huge game changer.
It won't replace the FX8 for live or for looper duties I don't think.
I'm using it with a Focusrite Red 8 Pre or Apogee Symphony into Logic or Pro Tools.
CPU usage is pretty high at this stage but I expect that might come down a bit.
The below graphic shows how much of one core the Helix and Slate VMR with a compressor and EQ on it will take.
By itself the Helix takes about 1/2 of one core on a 4.2ghz i& iMac 5k 27" with 40GB RAM at 32 samples.
I'll try it on the Protools rig later.
Does anyone know if you can have multiple authorisations or not?
I run Pro Tools and Logic on separate systems at the moment and it helps to not have to move authorisations all the time.
