Behold my massive board of pedals
1199200202204205394
  • The following is all relative obviously, but I’ve redone my board, and stripped right back. Made a few big decisions around functionality and priorities for live playing, and but for a couple of midi connections (waiting on a midi box) it’s all done.
    http://i.imgur.com/kKVhbvC.jpg
    First impressions are really good - it’s unfussy and uncomplicated (again, relative) but hugely powerful and versatile. 8 pedals controlled by the Morningstar MC6 too.
  • sgosdensgosden Frets: 1994
    Not trying to squeeze the moog On?
    Nope, that’s going to stay off the board, safe for studio / synth use.
  • DesVegasDesVegas Frets: 4559
    edited February 2018
    I've had this config for a while now and it swishes and a swooshes just right.
    https://i.imgur.com/aIRfq1L.jpg
  • althyalthy Frets: 92
    what do you need to make the ottobit jr midi controlable by say a boss es5?
  • Just a midi box and a patch cable
    Stripped right back... To 16 pedals!
    :-p
    :-p
    I did say it was relative!
  • Anyway, it’s 15 ;)
    I counted the expression pedal too innit
  • Paul_CPaul_C Frets: 7810
    This is my current (i.e. this month) setup.
    tucked away on the left is music stand no. 3 which I'll no doubt need sometime this year ;)
  • BeexterBeexter Frets: 599
    Just completed this for when I'm not using the AX8....all on a Metro 20....
  • This is my board at the moment. Just bought the Neunaber Wet and EXP. It's a work in progress but I'm pleased for now. I use this for both electric and acoustic as I can't afford 2 boards and don't have space for a loop switcher.
    The Boo Instruments pedals are brilliant - was going to sell the tremolo to create a bit more space but decided to keep it.
  • No flies on me.. just finalized it this morning following the arrival of the Tube Dreamer +, courtesy of @Jeebas. ;
    .. more pedals than i think i've ever used, but really digging having four stages of drive. Went minimalist.. went back..
    Might add a chorus and an octave at some point, all the essentials are there tho!
    ''i've not seen a reaction like that in here since George Best got kicked out for glassing a bouncer''
    The last iteration didn't last a day...final revision below.
    The Tumnus is in front of the Gain Changer and TD-X in the chain. The Jack Rabbit is last in the chain and serves double duty as a clean boost. I've also set up a preset on the Echo System that gives me a chorus too so that's another double duty pedal.
    Power from a DC-5 under the board. For those struggling with the depth of the DC-5 under a Metro board, I used GigRig's attachment method - take off the feet and the mounting screws. Put pieces of the rough velcro/ pedalboard tape at the edges of the power supply to stop it moving and then a couple of cable ties to secure. Works like a charm. Check out the Matt Schofield pedal board build on YouTube for a video run through on how Dan does it.
    Another tip I've stumbled across is that if I use the volume pedal instead of rolling down the guitar volume, the drives clean up without any treble loss - nice.
  • @JackieB33 Nice, hide the power supply and stick more stuff on there :)
    @beexster Tasty!
    @beexster Tasty!
    @Winny_Pooh Read my mind mate!  ;)
    Quality in every direction
  • builttospillbuilttospill Frets: 457
    https://i.imgur.com/2Z3Gbul.jpg
    Slightly revised 2018 rehearsal board. added the brilliant OD-1, SD-2 & DM-2w. Gradually going all Boss. I'd like slip on a Lovepedal Babyface Trem on there at some point.
  • https://imgur.com/gallery/Ysowy
    How does the RYRA stack with the SD-2? Guessing the chain is RYRA>....SD-2?
    Are you using both channels on the SD-2?
