http://i.imgur.com/kKVhbvC.jpg
First impressions are really good - it’s unfussy and uncomplicated (again, relative) but hugely powerful and versatile. 8 pedals controlled by the Morningstar MC6 too.
https://i.imgur.com/aIRfq1L.jpg
:-p
This is my current (i.e. this month) setup.
tucked away on the left is music stand no. 3 which I'll no doubt need sometime this year
This is my board at the moment. Just bought the Neunaber Wet and EXP. It's a work in progress but I'm pleased for now. I use this for both electric and acoustic as I can't afford 2 boards and don't have space for a loop switcher.
The Boo Instruments pedals are brilliant - was going to sell the tremolo to create a bit more space but decided to keep it.
.. more pedals than i think i've ever used, but really digging having four stages of drive. Went minimalist.. went back..
Might add a chorus and an octave at some point, all the essentials are there tho!
The Tumnus is in front of the Gain Changer and TD-X in the chain. The Jack Rabbit is last in the chain and serves double duty as a clean boost. I've also set up a preset on the Echo System that gives me a chorus too so that's another double duty pedal.
Power from a DC-5 under the board. For those struggling with the depth of the DC-5 under a Metro board, I used GigRig's attachment method - take off the feet and the mounting screws. Put pieces of the rough velcro/ pedalboard tape at the edges of the power supply to stop it moving and then a couple of cable ties to secure. Works like a charm. Check out the Matt Schofield pedal board build on YouTube for a video run through on how Dan does it.
Another tip I've stumbled across is that if I use the volume pedal instead of rolling down the guitar volume, the drives clean up without any treble loss - nice.
@beexster Tasty!
Slightly revised 2018 rehearsal board. added the brilliant OD-1, SD-2 & DM-2w. Gradually going all Boss. I'd like slip on a Lovepedal Babyface Trem on there at some point.
How does the RYRA stack with the SD-2? Guessing the chain is RYRA>....SD-2?
Are you using both channels on the SD-2?
