Gibson SG in hot pink fade
  • valevale Frets: 1052
    it looks like something left over from the spanish inquisition. new from gibson...'the double interrogator'!
    hofner hussie & hayman harpie. what she said...
  • sweepysweepy Frets: 4208
    24 fret SG's are wrong, so very wrong
  • CHRISB50CHRISB50 Frets: 4335
    It reminds me of using a highlighter, when it’s running out. It just looks unfinished.
    I hate the non symmetrical paint job.
    Not for me.
  • UnclePsychosisUnclePsychosis Frets: 12966
    If the whole thing was finished in the lighter pink it would be awesome.
    As it is, I'm out.
  • NeilNeil Frets: 3644
    Hideous.
  • BigsbyBigsby Frets: 2963
    dazzajl said:
    I like it more than I like most SGs. Always thought it a bid odd that the the guitar that’s supposed to be the rebel and demon is actually the most conservative of all.
    Who says it's supposed to be a 'rebel and demon'? It was designed to replace the failing Les Paul - which looked like your granddad designed it by the light of a gas lamp - and compete with the Stratocaster - which looked like it had come from the future. Gibson's previous effort, the Explorer, Flying V and Moderne in '58, hadn't done too well, so they chose a middle path with the SG. And it worked, and kept Gibson in the business of selling solid body guitars.
    If the idea that it's supposed to be demonic comes from the horn shape - well, that's a bit like saying the 335 was supposed to be Walt Disney-ish because the horns look like Micky Mouse's ears!
    As for these HPs, I think the fade is the wrong way around, it would look better with the horns coloured, and fading to dark at the rear of the guitar, like the old Lavaburst finish:
    Personally, I'd rather have two more frets than a little plastic tenon cover. Why they didn't have 24 frets from day one is a mystery to me, perhaps they just didn't think of it. "We're going to end up with a gap at the end of the fret board... I guess we can cover it with plastic."
  • rossirossi Frets: 1708
    i could live with it .
  • Musicman20Musicman20 Frets: 2342
    If it was like a 60s pastel pink, I'd like it.....but that is gross.
  • jonnyburgojonnyburgo Frets: 12434
    Looks like an old red MG that’s in a driveway near me, the licked red smartie look.
    "OUR TOSSPOT"
  • LodiousLodious Frets: 1947
    Nothing a total refin wouldn't cure.
  • zepp76zepp76 Frets: 2534
    Schnozz said:
    Jack_ said:
    Looks like it's on its period.
    +1 Oozes period IMO
    I couldn't afford it just yet, it's the wrong time of the month.
    Tomorrow will be a good day.
  • stickyfiddlestickyfiddle Frets: 27307
    FWIW SG controls are never symmetrical. But normally they're attaching to a decent looking guitar with the socket on the front so noone notices.
    One you put the socket on the edge it makes the whole thing look really odd. Very strange design decisions.
  • 57Deluxe57Deluxe Frets: 7348
    <Vintage BOSS Upgrades>
  • JotaJota Frets: 465
    It could always be worst. Not much but worst.
  • OilCityPickupsOilCityPickups Frets: 10787
    I actually rather like it ...
    Putting the jack socket on the edge means a. you don't have to have a right angled jack to avoid bashing your hand on the jack plug if you do 'windmill right arm' (yes I do ... embarrassing, but there you go). Also, I have lost count of SGs with nasty cracks around the jack socket as it's normally just backed by fairly thin wood rather than a metal plate.
    Having two extra frets seems a good use of otherwise wasted space.
    The colour scheme ... I don't mind it.
    The odd thing about that image is the humbuckers seem to have no mounting feet or height adjustment ...
  • impmannimpmann Frets: 12685
    Sorry but just no.
  • SnagsSnags Frets: 5420
    I quite like the colour, although would have preferred it if the dark red had, er, bled around to the lower bout a bit more so the white/pink is framed slightly.
    Not keen on the control positioning, though - they all look far too close together and not properly spaced/aligned.
    That appears to be conventional SG spacing ... whis both closer than LP and not regular (neither is a LP) ... it's just lack of the jack socket on the front makes it look different.
  • BellycasterBellycaster Frets: 5870
    57Deluxe said:
    Dessert Burst
     B)
    Only a Fool Would Say That.
