With thanks to this useful site, for all the model names they are based on. https://helixhelp.com/models/amps/guitar/
Presets, Download Paul Hindmarsh's from the L6 web site, dont bother buying any unless they are just for inspiration. Just create your own using bits of gear you know well, and then try out the bits you dont know so well in due course, dont rush things
Have you got any you have uploaded to Line Custom Tone? Would be good to see how you create these & what settings you use.
my main stereo patch is up ther
Just downloaded the "Stereo Metal" patch
set the volume knob to only affect the 1/4 outputs
ill upload a preset with that routing if you need
2 there are tone generators which could be tweaked to do something similar via one of the footswitches set to momentary
3 yes at the top of travel there is a toe switch that switches it to wah
you could do other funky thinks though like enable the wah via a footswitch or have the wah auto engage based on position
plus you can add anothe exp easily
New Amp Models (2—Helix, Helix Rack/Control, Helix LT only)
- Cali Texas Ch1, based on* the clean channel of the MESA/Boogie® Lonestar
- Placater Clean, based on* the clean channel of the Friedman BE-100
New Effects Models (4)- Distortion > Deranged Master (Mono, Stereo), based on* the Dallas Rangemaster Treble Booster—WARNING! Like the real thing, this model can take your head off! Works best before a distorted amp
- Distortion > Deez One Vintage (Mono, Stereo), based on* the BOSS© DS-1 distortion pedal (classic Made-in-Japan version)
- Distortion > Deez One Mod (Mono, Stereo), based on* the BOSS© DS-1 distortion pedal (Keeley mod version)
- Looper > 1 Switch Looper (Mono, Stereo), Line 6 original (doesn't leave Stomp mode)
* All product names are trademarks of their respective owners, which are in no way associated or affiliated with Line 6.Using the 1 Switch Looper:
Found the Friedman clean quite flubby and lifeless though
Not so much a "here’s how to create this tone video" but more a "this is what the unit can do" if you set paths etc. up a certain way?
