https://www.soundsgreatmusic.com/products/hiscox-electric-gibson-guitar-hardcase-std-eg?variant=829761651&utm_medium=cpc&utm_source=google&utm_campaign=Google Shopping&gclid=CjwKCAjwzenbBRB3EiwAItS-u92xVy6o4CAZhBQXYeXI7myBpIcmWCm6FUWqtiCHGE00CwxrBhEWzBoCF6QQAvD_BwE
The other ABS-type cases are not the same, even though they look similar - the Hiscox has a unique construction which makes it far stronger.
Ebay mark7777_1
Just because you're paranoid, don't mean they're not after youAnother vote for Hiscox on the hard case or to add Mono as a gig bag.
They're the only two I use - well made, hardwearing and protect the guitar well.
All you need is a zip to fail or a case handle to break and it's a lot more money lost than you've saved on a cheaper case.
I used to spend a lot of time shotgun shooting, there the cases (similar to gigbags) are zipped and unzipped at every stand - so you open and close them more. I several times saw zips fail and the stock on the gun break (same as a neck break on a guitar) when it hit the ground - just not worth the risk
Assuming needing an LP shape means you have an LP or similar its a shape that's pretty vulnerable to breaks ( I'm more fine with a gig bag for a strat/ tele) so if it's worth more than £200 ( arbitrary figure but clearly a £99 case will be a bit OTT if it's a £60 Harley Benton) then Hiscox.
Plus good padded bag option - PRS or MONO better still - if you are personally looking after the gig bag, so no roadies in the back of a tranny van full of gear etc, then a good big bag is fine and more practical on the move
However, if I had a Gibson style headstock I’d have a Hiscox for it....
Remember to check out our Bank Holiday Sale 15% off New, Used and Vintage
https://reverb.com/uk/sales/bank-holiday-sale
A Mono is actually more expensive than a Hiscox - I use them for both guitar and bass, because their other advantages are useful to me, but if I didn't need to occasionally carry my instruments on public transport I would get Hiscoxes. And I still wouldn't put a Mono in a van with a Gibson in.
