But like I said, the Helix range does other things so well they can both co-exist happily.
Edit: actually the Placaters aren's as bad as I thought...
In conclusion, two amps can be done but it depends on which ones and what else you want in there with them.
https://www.thefretboard.co.uk/discussion/57776/handsomerik/p1
Again my opinion :shrug:
I actually have TWO set ups; one for home and one for live/rehearsal...
I still own two DXR 10s (we use them for the band as PA), and I do like them. Sound good, if not a bit bright/digital for my liking. Mind you, I played through two last night with the Kemper and they sounded mighty
So,
1.) Home - I use Genelecs 8020s and 8010s
2.) Live - Red Sound LP12
However, I find that setting the hi and lo cuts to be vital in Helix. NEVER use the cuts in the cab or IR block as they have a strange curve. Always use a separate Hi Lo cut block.
There are a few not so good models in Helix imo but I think that the Matchless, Litigator, Plexi BRT, Deluxe, PRS dirt channel, Lonetsar Clean, Mod 2204 and even the Placater are as good as any profiles I've ever played through. There's a lot fo crappy profiles out there too just like there's not so good amp models in Helix. The Hi and Lo cuts are really important though.
Next is to try it more into an amp as purely FX which should be fun.
The HX Edit software is great. As stated in the Kemper thread it would be amazing to have similar on that platform too.
Definitely wanted the USB driver and editor so went to the Line 6 website. You have to create an account to download anything so I tried to do that. After numerous attempts on my PC and iPad, all I'm getting is error messages. I'm getting an OK against all the fields so no idea why it won't allow me to create an account.
Anyone else had this problem? Any advice @rossyamaha ?
Channel is a combination of tips (moreso in the earlier days of Helix) and demos of his free presets (Fridays I think) and the paid-for preset packs he does. I like his vibe.
