You can get more using MIDI
I'm guessing based on the presence of a USB port and a CTL/EXP jack that you'll be able to tweak stuff and set up CTL functions with an editor.
MIDI via TRS isn't too bad- adapters only cost a couple of quid.
200 via midi
http://cdm.link/2015/08/used-stereo-minijack-cables-midi/
A post on Gearslutz suggests some standards of wiring are now coming in.
https://www.gearslutz.com/board/showpost.php?p=13485912&postcount=21
So with the Boss pedals they will be of the Type A variety.
https://www.boss.info/us/products/bmidi-5-35/
mini trs - midi
with a right angle jack = very good idea
The DD200 appeals to me more than my DD500 in a way. A bit more portable, has all the features on it that I would ever need, is simpler to use by the look of it.
I'd put money on there being an editor that will let you get at least some of the in-depth stuff, and I imagine there will be quite a few downgraders who will thank BOSS if presets are transferable between the 500s and the 200s.
Only then you're left with only the two-engine expanded series/parallel capabilities and the £100 price gap to differentiate between the 200s and 500s. I wonder if they aren't cannibalising their own market...
one of the things that seems to be missing on the DD200 is the vintage digital setting, which I believe is a recreation of the 2290 or maybe a Korg. Can’t remember off the top of my head
Facebook: @northernstomps // Instagram: @northernstomps // Twitter: @northernstomps
Specialist Retailer Of Handmade British Stompboxes // https://www.northernstomps.com/
Currently Stocking: Hudson Electronic/Raygun FX/Zander Circuitry/ThorpyFX/Rainger FX/Life is Unfair/ Magnetic Effects/Fredric Effects
It would be pointless having midi and not have the capacity to have loads of savable presets.
It's like someone giving you the keys to a car with 500 bhp with no wheels on it.
